Slight rub with 285/75R16s
Old 05-17-2018, 10:16 AM
flainn's Avatar
flainn
flainn is offline
I changed out my stock 235/85R16s for new 285/75R16s, after doing quite a bit of research that indicated I shouldn't have rubbing issues.
Well, I mostly don't. I have an occasional rub but only when turning left, and -- strangely -- not at full lock, but rather at about midway between straight and full lock. Doesn't seem to happen at all when turning right.
Can you guys give me some suggestions for how to resolve? Do I need to shim the bumper (and how?) or is it likely something simpler like just trimming or adjusting the inner fender?
Old 05-17-2018, 10:24 AM
BuddyBarnes's Avatar
BuddyBarnes
BuddyBarnes is offline
My bumper is shimmed (washers) out a bit and I have plenty of room. Good part is you can not tell unless you really inspect close. Are you hitting the fender or bumper? Can not get much simpler than shimming the bumper. imo
Old 05-17-2018, 10:30 AM
flainn's Avatar
flainn
flainn is offline
Dunno where exactly it's rubbing, it was dark last night after I got the tires put on. But I'll report back.
What all is involved with shimming the bumper?
Old 05-17-2018, 10:48 AM
BuddyBarnes
Just put washers between bumper and frame.Loosen both sides then add washers one side at at a time. If I remember correct. Last time I was under mine for that was to remove some washers to go from 16.5 to 16 in tires. Been a while but easy.
Old 05-17-2018, 10:53 AM
flainn's Avatar
flainn
flainn is offline
Cool, man. Even I can handle that. Thanks for the info.
Old 05-17-2018, 12:48 PM
7.3 forever's Avatar
7.3 forever
7.3 forever is offline
I used I believe 3/4 bolt nuts as spacers on mine worked perfectly when I was at stock height and 285/75/16
Old 05-17-2018, 01:19 PM
green_95's Avatar
green_95
green_95 is offline
I took a saw zaw to mu bumper corners, never can tell.
Old 05-17-2018, 01:28 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
mine was done by PO
just have to take some of the bumper lower corner off
Old 05-17-2018, 05:11 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
Granted mines 2wd so yours might not need as much, I spaced the bumper 2" with 2x2 square steel tubing, and still had to cut out the bottom corner on the bumpers, i run 285 75 16 with no rub, and have some ricer 20" wheels with 305 55 20 tires and dont rub at all, I love the width of these wheels, it has better traction and when pulling the goose neck camping trailer its stable as a mule.
Old 05-18-2018, 10:57 AM
flainn's Avatar
flainn
flainn is offline
I looked at it, and the only part that is rubbing is the passenger side, lower corner of the bumper, only about half an inch. I may just use an angle grinder on it since it's such a small chunk.
Of course, it'll be interesting to see what happens once I get this thing offroad.
Thanks for the tips, guys. And knottyrope, that is a sweet looking ride.
Old 05-18-2018, 01:42 PM
knottyrope's Avatar
knottyrope
thank you
I was showing it for the bumper and I have 35s on it that only rub on the leaf spring during hard left
Old 05-21-2018, 04:24 PM
flainn's Avatar
flainn
flainn is offline
Used an angle grinder to remove a very small bit of material from the right corner of the back of my front bumper, and the rubbing issues are gone -- even after some decent four-wheeling action this weekend. I basically just gave it a smoother curve from the bottom to about two inches up.
Old 05-23-2018, 07:47 AM
knottyrope's Avatar
knottyrope
no before and after pics?
Old 05-23-2018, 10:28 AM
flainn's Avatar
flainn
flainn is offline
Are you talking about the bumper, or the tires/wheels? I didn't actually take any pictures of the bumper, but I could take some "after" pictures if you want.
Old 05-24-2018, 02:54 PM
knottyrope's Avatar
knottyrope
take one of the whole wheel well with bumper
could help someone to understand some day
Quick Reply: Slight rub with 285/75R16s
