ABS Code 3
Old May 16, 2018 | 09:11 AM
phayhome's Avatar
phayhome
Exclamation ABS Code 3
Recently replaced the brakes on all 4 corners, master cylinder, just figured out how to retrieve the abs codes. pops a code 3. has spongy brakes good pedal at first but then pedal goes to the floor. Need some guidance.
Thanks
Old May 16, 2018 | 09:53 AM
Scott in TX's Avatar
Scott in TX
Can you share with us how you were able to retrieve the codes? What year truck do you have?
Old May 16, 2018 | 10:34 AM
phayhome's Avatar
phayhome
I have a 1994 F250 7.3 IDI/Turbo Charged. Use the link below for the instructions. The orange and black wire with the connector can be a little hard to find. It can be under the dash behind the brake pedal, in the engine compartment near the OBD connector or behind the glove box. Which is where mine was located.
http://users.isp.com/vmstep/stuff/RABS_diag.pdf
phayhome
Large Truck
May 16, 2018 06:11 PM
GoGo Gadget
1983 - 2012 Ranger & B-Series
Feb 17, 2016 11:24 PM
bradleyjpyle
Jun 19, 2007 09:33 AM
therigwelder
May 13, 2007 08:16 AM
