Sponsored by: Real Truck
brake problems
Old Jan 26, 2003 | 05:04 PM
therigwelder's Avatar
therigwelder
brake problems
i have a 92 f-350 crewcab with a 7.3, i have replaced the brakes all the way around,replaced the master cylinder and bled the entire system several times, and i have to stand on the brakes to get it to stop the pedal goes to the floor and pumping the brakes just seems to make the truck harder to stop and when standing on the brakes the truck will slide often, no abs light comes on except on initial startup ,which is normal, ocassionaly the column light begins to blink when i am at a stand still and begin to accelerate in soft dirt and put a strain on it but according to the code reader i have that is a TPS problem.
does this year truck have the RABS or the RABS II,and is the controller by the pedal or behind the box also does anyone know how to ground the system to obtain codes from the abs light
Old May 13, 2007 | 08:16 AM
USMC Diesel's Avatar
USMC Diesel
Sounds like the sending unit for the ABS wheel sensor may be dirty.
