I have a 78 f150 roller 302 eldelbrock intake holley carb, mustang shorty headers and c4 trans
Its not a daily driver.
Currently the truck has 2.75 gears 28 spline. Found a 31 spline 3.25 geared rear end at a good price.
Would that make that much of a diffrence in low end? The truck just have much go on the low end.
Or should I keep looking for 3.50 or 3.70 gears?
Making that gear change will give you more grunt off of the line. The size of the rear tires will also make a difference. If both axles are Ford 9 inch rears, you can easily swap the third member and axles without having to swap the whole rear end. Just make sure that the bearings on the axles ends are the same size.
I'll bet the side bearings are different all together on these 2 axles. The 28 spline 2.75 I have has bearings that install into the axle housing. 31 spline has press on bearings with a spacer. Best bet is to swap entire axles and be done. 3.25 is determined to be about the best performance / gas mileage combination with stock tires.
You are confusing side (differential) bearings with axle bearings.
The 'slim line' side (differential) bearings are the same for all 9" rear axles (excepting 1970/72 F100 with 9 3/8" ring gear) beginning in 1969 from serial number J30,001:
C9AZ-4221-A bearing (stamped with BIN: LM102949) & C9AZ-4222-A bearing cup (stamped with BIN: LM102910).
1974/79 F100 & 1975/79 F150 with 28 & 31 spline 9" axle shafts. There are TWO different types of axle bearings:
3.50 is a good compromise gear if you dont have overdrive. I recently changed to 3.50 from 4.10 gears and didn't notice a loss in acceleration or grunt at all, my 408 has plenty of torque though. 3.73 and 3.50 are so close you wont notice a power difference
Of course you didn,t lose any grunt or acceleration going from 350 to 410, the bigger the # means lower gearing not the other way around. Going from 410 to 350 would slow the truck down off the line, going from 350 to 410 always gives better grunt and acceleration but you lose top speed.
Contrary to what ND just posted, there are 2 different bearing types to look for. One set of bearings are not tapered and have the seal in the housing ahead of the bearing. The bearings are "permanently" sealed and lubed with grease. The other has tapered bearings that are pressed onto the shaft with a spacer. They have the seal outside the bearings, so they are lubed by the gear oil.
Open your peepers, I said there were TWO different types of axle bearings.
The thing is, you called the bearings by the wrong name. Side (aka differential) bearings are NOT axle (aka wheel) bearings.
I posted the parts catalog pic so you could see the difference. Go back to post #5 and look at it again. (sigh)
Sorry I read your post wrong. I was just trying to make it clear to OP that you can't just grab one and shove into the other. When in doubt, swap entire rear axles.
I'm trying to be cheap and not have to pay someone to swap the gears. I found some 28 spline 3rd members rebuilt with 3.50 gears for $800. Dont really want to or afford to pay that.
I have a 1976 F100 2 wheel drive with a 3 speed Hurst floor shifter, a 302 engine with a Edelbrock intake, Holley 600 cfm 4 barrel carb., and a ford 9 in. rearend with 3.25 open gears and I am totally unimpressed with the acceleration from a stand still. I will be changing to a 3.73 possi. third member as soon as I'm financially able to.
Are you familiar with how to adjust doors on a 77 f100. I took the door and hinges off to clean an repair. Now I can’t get it back lined up, if you know a way I can get it back line up I will greatly appreciate it.
