Frame work
Old May 26, 2018 | 04:26 PM
seaves46's Avatar
seaves46
It may not be pretty but if you can , leave it there .
The stiffer your frame the better your truck will handle with your suspension setup .
As stated you can cut holes where need be to run exhaust and brake lines etc .
Just make sure you cut round holes and not square holes , as the corners of square holes give places for cracks to start .
Old May 26, 2018 | 07:11 PM
EBEAR's Avatar
EBEAR
The troubles are mostly self inflicted , but my errors began by using a 302 with the aod to make my mounts " same block right " and set it as low as possible . While assembling the 408 engine I found that the oil pan is not interchangeable and that the 351 has a substantially deeper pan making a 2+ " lift necessary . This in it self is not a disaster but has gone down the line . With the lift , the taller deck and the tall valve covers my booster no longer fits so must be moved to the other side of the steering column , pedal needs to be remade , have made my second trans mount , exhaust now aims into the X frame and stainless does not bend well , the trans now hits the fire wall and trans cover and I'm not entirely sure of the drive shaft clearance though the X frame . I may be overreacting if the driveshaft will clear the only problem solved by removing it will be the exhaust , all others are there to stay .
Old May 26, 2018 | 08:14 PM
56panelford's Avatar
56panelford
I'm sure you'll get them all sorted out..
spacemarine83
13
Dec 28, 2023 09:43 PM
riverguideguy
Oct 21, 2013 11:19 PM
tazcliff
25
Feb 15, 2011 04:45 PM
52'F-3
Aug 13, 2008 06:56 AM
psycosmith
1947 and Older Ford Trucks
Sep 14, 2007 11:06 AM
