Cat's Gone Bad!
Old Sep 19, 2003 | 10:00 AM
F1FiddyGuy's Avatar
F1FiddyGuy
Cat's Gone Bad!
Hey All, i need some help. I am the proud owner of a 1997 F-150 with a 4.2, 96,000 miles, 5 speed, all stock...except for my custom exaust, just a glasspack and chrome tips, nothing too fancy, but sounds great. Anyway, I'll get to the point. Last week, i started hearing this clanging and rattling from under my seat whenever i was next to sidewalls on the freeway or anything. Now today, i hear it all the time, even with my window closed. It seems to be whenever the engine is not providing constant pressure to the exhaust system, so it gives it some room to rattle. i am assuming this is my cat, on the driver side, going bad. I just need a second opinion. Has anyone had this problem before? I called the dealer and they quoted me some bogus price of like $1300.00 a side to fix, or like $2700 for both, they said parts alone were $1000 a piece, which i know is b.s. Anyway, i need some help, should i just go to a midas or mieneke and get it fixed, or cut it out myself and let her fly without one, or is my cat not even going bad at all, and it's something else. I'm horrible at troubleshooting and just need some diagnostic help. Thanks in advance.
Ryan
Old Sep 19, 2003 | 11:08 AM
hhipp's Avatar
hhipp
Cat's Gone Bad!
If you don't notice any performance or driveability issues and the MIL (check engine light) is not on then it may only be the heat shield on the converter rattling loose. Any trust worthy shop can help you out by tack welding the shield back on with very little difficulty. If your converter'(s) are bad then you can replace them with an aftermarket direct fit unit for about 1/3 the cost of the OEM replacement part. Again a trustworthy muffler shop will do the trick.
Old Sep 19, 2003 | 03:42 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Cat's Gone Bad!
It sounds more like the heat shields on the cats are rusting off. If they are loose finish taking them off, won't hurt anything.
Old Sep 19, 2003 | 04:06 PM
ford5.8's Avatar
ford5.8
Cat's Gone Bad!
lol..$1300 Get a highflow for $80 and have it installed for $50..
danielwd
1983 - 2012 Ranger & B-Series
Jun 6, 2011 12:38 AM
g5poirot647
Dec 20, 2010 03:34 PM
mark996
Nov 28, 2010 03:51 AM
Ryan50hrl
2004 - 2008 F150
Jun 28, 2010 05:28 AM
Trailblazed
Mar 21, 2007 07:12 PM
