1963 ford f250 4x4 292 y block
I searched all part numbers i found on this site and cannot find a water pump or repair kit with a 3/4 inch shaft. is the only issue with 5/8 shaft alignmentof the pulleys? my water pump is making a lot of noise but no real leakage out of weep hole yet.
Passenger Cars and early C Series tilt cabs used a different 272/292 water pump. Diameter of shafts are not listed, only their lengths.
B6C-8501-B .. Water Pump - shaft is 6.04" long / Obsolete
1956 F100/600 272 except H/D engine / 1957/64 F100/700 272/292 / 1961 C series Tilt Cab 292 from serial number 160,001 / 1962/64 C series Tilt Cabs 292 / 1963/64 N/NT500/600 292.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
------------------------------------------------------------------------------ B6C-8591-A .. Water Pump Repair Kit - Use with B6C-8501-B Water Pump / Obsolete
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
When used with a matching pulley, there is no alignment issue with a car pump. For most Y-Block truck applications, a car pump with pulley will be a direct interchange with a truck pump with pulley. You simply cannot mix pulleys between the two.
