Sponsored by: Real Truck
Power stroked
Old May 10, 2018 | 07:05 PM
lake and stream's Avatar
lake and stream
Power stroked
2005 f350 190k
Was pulling the boat home the other day and ECT hit 206 and the truck turned off . No check engine light . Let it sit temp went down to 190. Fired up almost made it home same thing .
This is the fun part , I live in ga and this truck typically runs about 170 deg . I have a upgrade radiator and I never had any issues so I didn't think anything about it . Well after the above issue I decided at 190k miles I'll change the tstat and fan clutch assembly easy pz . Well not the truck runs 190 deg and gets to 193-197 while driving . Engine oil stays around 175-185 . From what I've found searching that's "normal for my area "
Haven't got to hook the boat up yet and see what happens but my main question is what could cause the truck to die at 206 twice and do you think the tstat that was in the truck was stuck open for almost a yr and a half ?
Old May 10, 2018 | 07:39 PM
Yoteman's Avatar
Yoteman
Originally Posted by lake and stream
2005 f350 190k
my 04 always runs about 170 too. I’ve figured I’ve got a bad tstat. I’ve been planning to replace it to bring it up to around 195. I’ve read that’s optimal for these trucks and better mpg too. And regardless how well your radiator is, your tstat should maintain the set tstat temp if it’s functioning properly.
Old May 10, 2018 | 08:22 PM
Tideman's Avatar
Tideman
Do you have any way to monitor data or check for DTC ‘s. Water temp @206 will not turn truck off. What was oil at that time. If it had gotten too hot it would have thrown a CEL then defueled before it shut completely off (somewhere around 240). Something else is going on.
Old May 10, 2018 | 08:40 PM
Tideman's Avatar
Tideman
This is Diesel 6.0 right? Forgot to ask. I stay on the 6.0 forum most of the time so I “assumed”
Old May 10, 2018 | 08:50 PM
lake and stream
Yes 6.0 diesel. Oil temp was about 200 . No codes
Old May 10, 2018 | 08:51 PM
lake and stream
And yes edge cts display on the dash
Old May 10, 2018 | 08:52 PM
Tideman's Avatar
Tideman
What are you monitoring with?
we must have replied at same time
Old May 10, 2018 | 08:56 PM
Tideman's Avatar
Tideman
I don’t know the edge CTS. Will it do ICP and IPR ?
Old May 11, 2018 | 09:51 AM
lake and stream
Yes it shows pretty much everything
Old May 11, 2018 | 10:11 AM
Tideman's Avatar
Tideman
Post your ICP and IPR numbers during cranking and also running. I suspect that it has thrown a DTC and your Edge is not picking it up. It could be a list of many things. A wire short, a malfunctioning IPR. A shorting Cam/Crank sensor. EGR/Fan short. The cooling/oil temps you were showing will not cause a truck to shut off. Right now I highly suspect a failing IPR, BUT that is a GUESS. If you have a friend with ForScan or Torque Pro have them run a DTC scan on it to help narrow it down. If you don’t find it, it will sooner or later leave you stranded.
Old May 11, 2018 | 10:16 AM
lake and stream
taking it to the scanner at lunch . ill let ya know all the details
Old May 11, 2018 | 05:10 PM
lake and stream
Ok changed fan clutch,tstat,and Degas bottle and lid . Drove home everything seemed fine . Pulled in the driveway and truck died . This time I have a 2623 code
Old May 11, 2018 | 05:20 PM
EXSwap's Avatar
EXSwap
I believe that’s an IPR circuit code....time to dig in! Not sure if there’s a sticky on this, but I imagine there is...
Old May 11, 2018 | 05:56 PM
Tideman's Avatar
Tideman
Thats what I thought it was. I would replace the IPR and the pigtail. It’s up under/behind the turbo and a little bitchy to get to, but it can be done in about 45min or less. You’ll need a special IPR socket to get it off. Do not buy a chinese replacement IPR. Ford OEM only. If you shop you can get it for $200.00 or less. Good luck
Old May 11, 2018 | 06:28 PM
lake and stream
Good news is I'm not running over 201 deg even while pulling the boat so that makes me happy. Guess i cant complain about typical maintenance. New Motorcraft IPR on the way .
