Rounded 8mm ebpv bolts
Old May 10, 2018 | 02:35 PM
540milotalon's Avatar
540milotalon
How do you guys get the 8mm bolts off the ebpv when they rust and then are too small for ANY brand 12 pt tool to fit?
Old May 10, 2018 | 08:06 PM
nateairman's Avatar
nateairman
Is the turbo on the truck?
Old May 10, 2018 | 08:10 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Turbo removal and rotary tool is where I would start.
Old May 10, 2018 | 08:52 PM
540milotalon
Turbo on truck. On this one, I got the easiest and hardest ones out but the one on top nothing I tried fit. I had to grind the head off with a die grinder, slip the valve off and then back the "stud" out after. The last truck I had trouble with was the lower one and we pulled the turbo (difficult) with the ebpv valve still on.
I was simply hoping there was some magic Sn-- On, M-c, Mat-- tool to use. Even Chinese??
Old May 11, 2018 | 08:17 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Did you try a pipe wrench?
I have never removed the EBPV before taking the turbo out. I use a shorty wrench and a prybar to break the collector bolts and nuts.
Old May 11, 2018 | 08:38 AM
540milotalon
Maybe I'm not using the correct nomenclature. I am having a problem with the valve itself (collector?) - exhaust side of turbo - and not the actuator behind the turbo itself. I too have used either a stubby wrench and a dead blow hammer or a 1/2 moon wrench and dead blow. When the head is reduced by rust etc. 8 mm-5/16" will not fit, 7 mm is too small. Absolutely no space for pipe wrench and vise grips on the bottom would be impossible.
What to do next?
Old May 11, 2018 | 08:49 AM
farmert's Avatar
farmert
I have used these with some success when the head becomes rounded.https://www.ebay.com/itm/HANSON-Metr...UAAOSwv0tU8RE- I got my 5 piece set from my local Napa store.
Old May 11, 2018 | 08:58 AM
knottyrope's Avatar
knottyrope
can a dremel tool fit?
I use one for cutting exhaust bolts, studs, nuts all the time
die grinder helps in some places too
Old May 11, 2018 | 10:48 AM
Jarrett Campbell
Can you post a picture of the bolt that you're dealing with? I remember 10mm bolts on the pedestal, and 15mm on the collector, nothing 8mm
Old May 11, 2018 | 10:58 AM
farmert's Avatar
farmert
I think he is talking about the 3 bolts that hold the EBP piece to the turbo.
Old May 11, 2018 | 11:21 AM
540milotalon
The OBS has three (3) 8 mm diameter bolts with 8mm 12 point heads holding the exhaust flapper valve on to the exhaust side of the turbo. As I take these off (mine or someone else's) I replace with stainless steel and prefer socket head cap screws.
To to my way of thinking, it makes the turbo easier to remove. I stated above, I have removed one turbo without doing it first and seemed more difficult.
I used a abrasive cut off wheel on my die grinder because there was not enough room to work the dremel in there.
Old May 11, 2018 | 12:00 PM
Jarrett Campbell
I would just pull the turbo with it on and cut it off once you get it on the bench, but I might be crazy.
Have you pulled your downpipe out? That might be where my experience is different to yours. I pull the DP out before I go to get the collector bolts out, and there is plenty of room to work around the EBPV flange.
Old May 11, 2018 | 01:34 PM
540milotalon
As long as the 3" down pipe is still a 2 piece it isn't too hard to pull out. True, with it out you have more room but I still like to pull the valve prior to removing the turbo. If the bolts are rusty - rounded it ain't so easy to get them.
Old May 13, 2018 | 08:37 AM
540milotalon
Thanks everyone for tips/suggestions. I have found the Hanson set on ebay for $24.00 delivered. Hard to beat that much for something that might save lots of headaches.
Old May 13, 2018 | 09:04 AM
nateairman's Avatar
nateairman
It' an echo chamber here but.... That's 24$ you could have put towards a t4 setup
