What vehicle is it on? Year make and model, engine would also help
BlackDragon26
This is on a 2000 Ford F250 Super Duty......found out yesterday that i can pull a battery cable and it resets then can start it , but if you turn on headlights it will kill the motor.....i am thinking light switch at this time
checked out all grounds ..what looked questionable , cleaned so far no help Light switch good , ignition switch good ....anybody got any idea's why turning on any accesseries on in the cab kills the motor and everything in the cab ( 2000 Ford F250 )
Just to let all know what i found out on this truck ...did a test on charging system and battery ....turns out the battery had low voltage . Well ended up replacing the battery and took care of the problem ...voltage was evidently low enough to rob power and kill motor !!
