Bronco II Ford Bronco II
1988 bronco ii eats starters........
Old Sep 19, 2003 | 02:31 AM
lewie's Avatar
lewie
Angry 1988 bronco ii eats starters........
Have a 1988 2.9 bronco ii with 340000+ miles. About 15000 miles ago problems with starters occurred. Yes starters, just put the 5th one in her today! Have replaced the fly wheel but this did not help. 1/2 dozen starts today and I can already hear the grumblings of a worn starter????????? Please help...............
Old Sep 19, 2003 | 08:18 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
What type of failure are you having?
Old Sep 19, 2003 | 09:22 AM
lewie's Avatar
lewie
hello Ken. bearing in the starter drive goes out.
Old Sep 19, 2003 | 11:32 AM
AG4.0's Avatar
AG4.0
hopefully you're just replacing the starter drive and not the whole starter, mine went out in the 84 I used to have and it was only lik2 $15 for the starter drive, but I never hadproblems with it again after that.
Old Sep 19, 2003 | 03:34 PM
lewie's Avatar
lewie
live time gaurantee starter. replaced the starter every time at no cost. bearing keeps going out on the starter drive. why?????????
Old Sep 19, 2003 | 11:21 PM
tcbrad98's Avatar
tcbrad98
make sure that the starter you are using is a ten tooth starter and not a nine tooth, went through the same problem, 7 starters in 5 days, took the last one back to oreillys and went to carquest, bought a different type of starter, same problem, took it back and checked with the warehouse, they said that if it was for a bronco ii that i needed a starter with ten teeth, that was two years ago with no problems since.
Old Sep 20, 2003 | 01:42 AM
lewie's Avatar
lewie
Thanks tcbrad98. Ill certainly check onthis feedback and let you know how it turns out. thanks again.
lewie
Old Sep 21, 2003 | 02:28 AM
lewie's Avatar
lewie
Attn tcbrad98
Do you have a part number? Seems that the parts stores here in western SD can only count to nine. They seem to think a ten tooth is an imaginary part?????????????
Thanks again!
lewie
