Problems Getting 226 Started
Old May 9, 2018 | 05:28 PM
raytasch's Avatar
raytasch
Believe Nothing
Originally Posted by 3twinridges
It’s been a long time since I changed my pump but tightening those stud nuts to final torque should give you resistance as it actually is pulling the arm taught against the cam. If it just mounts flush against the block without a little effort it’s the wrong pump....IMHO
JB
And where the cam lobe is at the time of pump install, determines just how much resistance you feel fitting the pump into position. Try my witness mark suggestion.
Old May 9, 2018 | 06:38 PM
acl9865's Avatar
acl9865
Well I took off the pump to carb line and pumped it manually, sprayed fuel all over the garage so the pump is solid. Lined it up and bolted it back on, using a breaker bar I turned the motor over a few times but no fuel came out. I’m going to 3d print a few shims and attach them to the arm to see if that helps.
Old May 9, 2018 | 07:52 PM
Mixer man's Avatar
Mixer man
If it's the correct pump, no shims required. Shimming would be asking for trouble, imho.
Old May 9, 2018 | 09:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
JB
And if you can work the pump by hand, that is unlike any mech fuel pump I've installed. Very hard to operate by hand, even when the body is held in a vise.
Old May 10, 2018 | 09:57 AM
raytasch's Avatar
raytasch
Believe Nothing
Going to ask a very basic question here that will elaborate on what Ross said above. Does that pump have a very heavy spring that returns the arm to the 'home' position? Spring should be visible. And yes, the pump should be hard to operate by hand and you should feel resistance in positioning it to the engine.
Old May 10, 2018 | 10:26 AM
acl9865's Avatar
acl9865
Seems to me that the travel is very short when operated by hand. Maybe .25" of travel at the end, almost a click that ejects fuel out the end. With a two hand grip and both thumbs pressing on the arm I can fairly easily depress the arm.
It does, yes. I'll post some more pictures shortly. I wouldn't say the pump is EASY to operate but it's definitely not that difficult. I feel no real resistance when mounting it.
Old May 10, 2018 | 10:44 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The eccentric on the flat V8 cams only provides 0.200" of movement. I'd expect the 6's to be similar.
Old May 10, 2018 | 10:54 AM
acl9865's Avatar
acl9865
That seems much closer to what I'm seeing. I felt the eccentric and couldn't really tell it wasn't round. I'm thinking either the arm is too short/wrong shape or the gasket is too thick? Something is preventing that arm from getting its full stroke. Stand by for measurements.
Old May 10, 2018 | 11:06 AM
acl9865's Avatar
acl9865
acl9865's Avatar
acl9865
There was roughly 0.75" between the mounting face and then outside of the arm when fully depressed. As the picture shows I was able to full depress the arm with one thumb but decent effort.
Old May 10, 2018 | 12:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I think you may just be taking up the slack in the linkages. I'd estimate it takes 30 - 40 pounds force to cycle the diaphragm on most pumps. If that's all it's got, it's DOA.
Old May 10, 2018 | 01:34 PM
acl9865's Avatar
acl9865
Really? When I move the arm that last 1/4" it sprays fuel like 4'.
Old May 10, 2018 | 02:43 PM
  #28
raytasch's Avatar
raytasch
Believe Nothing
I am surprised no one has posted detailed pictures of a correct pump for the 226.
Old May 10, 2018 | 02:51 PM
  #29
ALBUQ F-1's Avatar
ALBUQ F-1
It appears to be the correct pump. (below)
The way the pump works, when the arm is squeezed like in your pic, the pump is sucking in fuel. When released, the springs in the pump force fuel out to the carb. So at the least, it sounds like your pump's check valves are not closing.
Old May 10, 2018 | 08:05 PM
  #30
Marauder2004's Avatar
Marauder2004
Ray had a good idea! I checked the pump I will use on my engine and confirmed it is identical to the one on the engine before the rebuild. After the arm reaches resistance it moves a good 5/8" by hand, very tight. Pictures attached.
Onus
Sep 18, 2012 07:03 PM
rwcmick
Mar 29, 2011 12:24 AM
Steelheader87
Mar 19, 2011 01:39 PM
jazzmaffy
Jun 15, 2010 04:49 PM
twwtruck
Jul 16, 2008 11:53 AM
