a little help please
Old Jul 15, 2008 | 02:35 AM
twwtruck's Avatar
twwtruck
Question a little help please
all right i was having trouble starting when warm so i changed fuel filter and fuel pump now it wont start any suggestions.
thanks
Old Jul 15, 2008 | 05:18 AM
mistakenID's Avatar
mistakenID
Did you fill the filter with diesel or something like diesel clean before putting it back on?
Old Jul 15, 2008 | 05:34 AM
PLC7.3's Avatar
PLC7.3
Did you install the pump correctly........
This info pertains to Carter #M60278 pump or new long arm style.
WARNING
This fuel pump must be installed only at the low position of actuator cam.
If the pump is installed at any other position than low cam, the pump will be ruined, the engine will stall and damage may result.
Incorrect installation will loosen the pivot pin and allows the pin and lever to come out of the pump and drop into the oil pan. This can occur immediately or after several hundred miles. This type of failure is not covered by warranty.
To ensure that the cam is at low position, it is necessary to use a mirror and a remote starter switch. Observe the cam through the mounting port and bump the engine around until a one (1) inch wide machine surface is observed. This is low position of the cam. Now complete normal fuel pump installation.
9502CA
1991
Old Jul 15, 2008 | 01:09 PM
twwtruck's Avatar
twwtruck
no i didnt fill the filter up or mess with the cam i just slid the pump in and put the bolts on
Old Jul 16, 2008 | 08:48 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
did you leave the pump gear on the truck and slide the pump in?
best way i think. anyways... i had a lot of trouble with mine as it has an aftermarket Racor filter separator as well as the factory. so it was hard to fill them. got them half full or so. i cracked the injector lines and all but my batteries were crap so i had to charge them a couple of times b4 i could get fuel to the injectors.
but it took a bit of cranking
Old Jul 16, 2008 | 11:53 AM
twwtruck's Avatar
twwtruck
ok ill try that
