Help with MII coil spring selection
Old May 8, 2018 | 06:55 PM
TAK1's Avatar
TAK1
I have a 1948 F1 with Mustang II front end, 383 stroker and TH 350 transmission. Does anyone have a similar weight setup and can share information as to the spring rate you're using? I have a tire rubbing fender issue and need about an inch more of clearance over 235/60/15 tires. Currently running 325 spring rate that are 9" compressed height.
Old May 9, 2018 | 12:58 AM
old_dan's Avatar
old_dan
I went through that. I have a 52 F1 with a 351W and a C6 trans. The MII springs that came with the kit had been shortened by a coil when compared to the new springs. I put in new springs....I went to Napa and picked the stock set for a small-block V8 Mustang. The setup is a Fatman Fabrications kit. Their website has a downloadable catalog. They recommended Napa p/n 277-3038 for small block equipped pickups.
That was great right away, but it settled in an inch with a little driving. I ended up finding some spring spacers at Summit. That added the inch back. It's been good for a couple of years now!
Dan
Old May 9, 2018 | 04:35 PM
ben73058's Avatar
ben73058
Hey Tak,
I second Dan's spring spacer recommendation. We put one in our '50 F1 so we could get around while
breaking everything in.. they work fine no issues. We ended up going with smaller front tires to get past the rubbing issue.
Nice looking truck over there in Washington.
Ben in Austin
1950 F1 (351W/AOD)
boehmtrent
Mar 29, 2015 02:10 PM
medicpg
Mar 10, 2010 10:48 PM
bsteele52
Dec 18, 2008 12:07 PM
gdub
Mar 23, 2007 10:30 AM
OilLeaks
Nov 27, 2006 10:22 PM
