Strange Clunking Noise
Old Sep 19, 2003 | 12:52 AM
Method's Avatar
Method
Angry Strange Clunking Noise
I own a 95 Limited. Recently i've noticed a loud clunking noise coming from my driver's side front wheel between 10 and 20 mph. The noise dissappears above 20 mph but turns into a bad shaking at 55 mph and above. Does anyone know what this could be, before I try to tackle this on my own.
Old Sep 19, 2003 | 05:29 AM
JPC's Avatar
JPC
Something like that should be very obvious if you jack up the front end and move the tire around or pull the wheel and look. It also sounds like it should be looked at ASAP.
Old Sep 19, 2003 | 02:00 PM
96explorereddieb's Avatar
96explorereddieb
Sounds like the ball joint. Jack up the front end and see if there's any play when you shake the wheel. If there're any plays, then it's the ball joint.
Old Sep 19, 2003 | 09:07 PM
NEOGEO's Avatar
NEOGEO
Talking Strange Clunking Noise
HAVE YOU HAD A LOOK AT YOUR RADIAL ARM BUSHINGS.......
Old Sep 21, 2003 | 09:12 PM
JSchilberg's Avatar
JSchilberg
Radius Arm Bushings
Old Sep 22, 2003 | 08:33 AM
96explorereddieb
2nd gen Explorers don't have radius arm bushings.
