Bed Rivets
Old May 8, 2018 | 10:41 AM
Carbonarc's Avatar
Carbonarc
Bed Rivets
My bed front had to be removed for replacement due to rust and need some advice on what to replace them with. I'm considering polished SS allen head button head bolts but appreciate hearing what's been used by others.
Old May 8, 2018 | 02:28 PM
jniolon's Avatar
jniolon
old and in the way
Curt, if you're talking about the bolts that hold the bed front to the bed sides... I'd use SS button head like you mentioned. you can also rosette weld them in place. Best I remember I used 1/4" half inch long
john
Old May 8, 2018 | 06:16 PM
Carbonarc's Avatar
Carbonarc
Thanks for the confirmation John. We'll see how it looks after paint, sometime this Fall.
Old May 8, 2018 | 10:16 PM
gup51's Avatar
gup51
I used "hiloks", which are low profile bolts with the allen socket in the tail instead of the head. They are used in the aircraft industry but can be purchased on ebay. After being painted the heads look almost identical to rivet heads.
Old May 8, 2018 | 11:55 PM
Carbonarc's Avatar
Carbonarc
GUP - that's brilliant! Thanks for the tip.
Old May 9, 2018 | 05:28 PM
petemcl's Avatar
petemcl
I just used ¼" x ¾" bolts with nylok nuts. It made a very tight fit and really stabilized the sides.
Old May 9, 2018 | 06:00 PM
CharlieLed's Avatar
CharlieLed
I no longer use bolts/screws...I use structural adhesive and eliminate the fasteners altogether. Very clean custom look but if you plan to disassemble the bed again sometime in the future you better pack a lunch.
Old May 9, 2018 | 06:13 PM
petemcl's Avatar
petemcl
Yes, I have seen you post that before Charlie. We actually have used that in production since the early 80s at Jeep in certain places. My box was in terrible shape, I think that they hauled engine blocks in it over every back road in Wisconsin for years, I needed to pull it into shape which the bolts did a great job of accomplishing. I just wasn't brave enough to use clamps and adhesive.
Old May 10, 2018 | 12:02 AM
Carbonarc's Avatar
Carbonarc
My bed front also had a couple of spot welds in between the bolts on each side. Maybe this was unique to Louisville?
Old May 10, 2018 | 08:39 AM
CharlieLed's Avatar
CharlieLed
In situations like that I use the existing bolt holes and bolts to pull the panel together until the adhesive cures. Once cured the bolts can either be removed or just grind off the heads. This technique not only looks very clean but it adds a lot of rigidity to the bed. Once you try it you'll wonder why you waited so long.
queen of spades
Mar 1, 2019 12:27 AM
adammdennis11
Sep 20, 2015 09:29 AM
Built_Ford_Tough_757
Feb 25, 2015 06:15 PM
DJdemon6696
May 24, 2009 06:51 PM
rcav8or
15
Apr 27, 2008 12:38 PM
