question screws throttle linkage
Old May 8, 2018 | 01:06 AM
rico56's Avatar
rico56
Hi there!
I'm in the process to replace my 239 y-block with the rebuilt 272. Can someone tell my, what size are those two screws circled in the picture?
Thanks in advan
ce!
Old May 8, 2018 | 03:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You posted a pic from the 1949/59 Ford Car Parts Catalog.
The part circled in red (7A185 accelerator shaft & bracket) was only used on 1955/57 Thunderbird 292/312 with stick & overdrive.
So, what are you actually working on, a car or a truck?
Old May 8, 2018 | 06:08 AM
rico56's Avatar
rico56
Hi Bill,
I was sure it would be You who replied first or so I hoped Thanks!
The new engine is for my truck ('56 F100) and it's a 272 bored over to a 292. But since I have another carb running on that engine then before on the 239, I have to change the whole throttle linkage assembly:
setup at the 239
new setup required on the 272 see circle
Right now, I'm planning to use the assembly which is installed on the 239 and make it fit to the 272 but therefore I need that two screws to mount it on the new engine.
So I just need the dimension of those screws.
Old May 8, 2018 | 09:35 AM
NumberDummy
Originally Posted by rico56
Hi there!
Thanks in advan
ce!
20346-S8 .. Bolt-hex head - Bracket to Intake Manifold - 5/16" -18 x 3/4" long / Obsolete
20310-S8 .. Bolt-hex head - Bracket to Intake Manifold - 5/16" -18 x 1/2" long / Obsolete
34806-S7 .. Lockwasher - 5/16" / Obsolete
Old May 8, 2018 | 11:42 AM
rico56's Avatar
rico56
Thank You Bill - perfect!
I've dug a bit deeper into that matter. It seems I'll need a whole new assembly. The old one from the 239 wont fit (the rods are different, especially the one that goes down to the kick-down lever at the fordomatic). It seems, the assembly I need would be from a 1959 or 1960 F100 with 292 y-block and fordomatic. I think, in the first step I'll mount a simple linkage just to get the truck running and disable the kick-down lever at the trannie for the time beeing. In the second step I'll look for a final solution to get the whole assembly running including the kick-down. Maybe someone can spare such a linkage assembly.
Old May 8, 2018 | 02:37 PM
NumberDummy
Upper pic 1956: (C = F100; D = F250; Y = F350)
Lower pic: 1957/60.
Old May 8, 2018 | 03:55 PM
rico56's Avatar
rico56
Thank you Bill,
it’s the assembly in that 1959-60 box in the lower pic that I need. I think I’ll start searching for those parts. Let’s see what turns up.
foster32203
Large Truck
Jun 12, 2019 11:13 AM
bluesalomon
Apr 28, 2016 08:34 AM
JHarsh
Oct 28, 2015 12:40 AM
Jafo56
Sep 24, 2015 07:44 PM
pcmenten
Apr 23, 2004 12:55 AM
