Need help with bleeding brakes
Hi guys.
I replaced a front left side caliper - bled the brake with lots of fluid using the old tube in glass method - but I still can't get pressure on the pedal, thinking I'd let the fluid down to far I bled the master cylinder - I've done this before, but never had this issue - just wondering if I have to bleed the other three or do I have some other issue?
When the engine is off the pedal is relatively hard to depress - with engine started the pedal goes to the floor with little resistance.
Any help would be appreciated as I need the truck for work on Wednesday
Thanks.
Since it's a 2003, I'd recommend you either do a two-person bleed on all four wheels, started at the wheel furthest from the master cylinder and working your way closer. Since it's a 2003 truck, chances are pretty good the brake fluid should be flushed anyway.
If you don't have a helper that can help you before Wednesday, then pick up either a MityVac system to do a one-person vacuum bleed or, from my experience, better yet, get a full set of "Speed Bleeders" and replace the bleeder screws with these one-way valve bleeders. Once installed, you just open them a quarter turn or so, connect your tube to the jar, then slowly pump the brake pedal a few times, making sure not to let the level in the master cylinder get too low.
-Rod
-Rod
Thanks for the response Shorod - after the copious pumping of the brake pedal there was a small "pool" of brake fluid on the ground under the rear passenger brake caliper.
I pulled the wheel, cleaned it off and got my neighbour to pump the brakes - fluid is coming out of the centre hole in the bleed nipple. This caliper is "new", installed around one and a half years ago by a dealership.
The nipple could have worked it's way loose or it could have failed. As it was getting late I decided to pack the tools away and get at it in the morning.
What amazes me is the coincidence - I have never had one of those fail on any vehicle or what might have happened if I'd lost brakes while driving.
At least I know what to do next , Lol.
Cheers - learn something new everyday.
-Rod
The bleed nipple came out with just my fingers, I bought a new nipple screwed it in and it seemed to bed down nicely, I bled that brake, but still not good pedal pressure - I looked around the underside of the nipple and there was a few drops coming out of the threaded hole and the nipple, which meant the threads had bee damaged somewhat - I replaced the caliper ($96 + tax) bled it and got the brakes working :
Here are a couple of pics:
-Rod
