towing advice
Old May 7, 2018 | 01:23 AM
grumps91331's Avatar
grumps91331
towing advice
1st off all thank you all for all the great info..these threads are awesome. Im looking for a travel trailer without overkill on my truck. All I have towed prior is a project car in my silverado..new to diesel and Im loving it. So to all you experienced in towing, what is the max weight travel trailer you can recommend that I can safely attach to my rig? please keep in mind truck and trailer would be loaded
with occupants n crap. .I will include pics of my 350s specs. thanks again.
Old May 7, 2018 | 04:39 AM
seville009's Avatar
seville009
Also depends on what trailer hitch you have (assuming you already have one). The hitch should have weight ratings on it too.
Old May 7, 2018 | 06:15 AM
Xwild's Avatar
Xwild
Yup.. bumper pull vs gooseneck/fifth wheel makes quite a difference in max trailer weight.
Old May 7, 2018 | 06:27 AM
Buliwyf's Avatar
Buliwyf
Looks like for bumper pull travel trailers, length will be your only limit. Looks like plenty of truck.
I like smaller, with slide outs. 23-25'. I'd love to see how guys with 30'+ TT's are making right turns in busy areas. Normal full weight, for durability. TT's usually aren't too heavy. I really like the Arctic Wolf trailers, but it's a little too long at 26'.
I don't see a GCWR on those stickers. But obviously that's a 350. The GC, or tow rating, is in the manual.
Old May 7, 2018 | 07:30 AM
ksteve06's Avatar
ksteve06
I’m towing a 31’ 10000lb Airstream and you just have to be careful turning corners.
Old May 7, 2018 | 08:15 AM
Clubwagon's Avatar
Clubwagon
Yep, a '17+, SRW, F350, 6.7 will have no trouble towing most any bumper pull trailer.
As noted above; check to ensure your hitch, drawbar and ball are all rated for the load. And a few other notes: To ensure stability be sure you have adequate tongue weight 10% of gross is a typical minimum requirement. For the really long trailers you might want to consider a weight distribution hitch w/ sway control. Make sure you have the tire pressure up to spec. Ensure your brake controller is adjusted properly.
Most importantly, before you head out on that first trip get used to maneuvering in tight quarters. A big empty parking lot is a great place to get comfortable. And be aware of how the trailer tracks behind the truck. It will track a tighter radius through a turn than the truck so you have to compensate by driving a slightly wider line to keep the trailer from dropping wheels or hopping curbs.
Old May 7, 2018 | 08:35 AM
bhbdvm's Avatar
bhbdvm
Max trailer weight should not exceed 80% of your tow capacity. You can exceed 80% to but better to be around 80% or less to have a better tow experience and to be safer. Remember your tongue weight affects your payload capacity. A weight distribution hitch can help eliminate some of the tongue weight if needed.
Old May 7, 2018 | 08:54 AM
Buliwyf's Avatar
Buliwyf
I generally hover around 60-ish% since I like to always be comfortable at 75mph. Say 7000-8000 with a 12,500 rated F250. Tow F150 sized trailers with a 250. 250 sized trailers with a 350. etc etc.
Old May 7, 2018 | 09:43 AM
Skimr's Avatar
Skimr
Couple of other things for you to consider for your searching. 1. Weight specs on trailers are all dry weights. That means no water on board, no propane in the tanks no battery upgrades, food, kitchen stuff etc. For example our 2016 model year lance 1995 has a dry weight of 4265 lbs and tongue weight of 365 lbs. Fully loaded with fresh water, gear, propane and dual batteries that jumps to 5700 lbs total weight and 700 lbs tongue weight. Turned out to be to much for the tundra we had NOT from a towing capacity but from a payload capacity. Payload on your truck is affected by nbr of passengers and dogs plus any standard add-ons like canopy, upgraded bumpers, any gear you are hauling in the truck bed and weight of the hitch stinger and the tongue weight. You should have plenty of room based on what your stickers show as long as you keep in mind realistic payload nbrs.
Old May 7, 2018 | 01:28 PM
grumps91331
thanks again for the great advice..I have the weighsafe 3 inch shaft with the 8 inch drop which I believe is rated at 21,000 lbs.. ..I just want to be sure before I start dumping more money on this beauty. .lol
Old May 7, 2018 | 03:38 PM
2009kr's Avatar
2009kr
Pretty much any travel trailer you want would be fine. If you want the ultimate in stability, a ProPride 3P or Hensley Arrow will make it even more stable.
Turns are no problem, you just need to learn to swing wide when making right turns; just watch any tractor trailer, they do it all of the time. The main point is to NEVER let traffic cause you to take a line that you don't want to. Figure out where you need to drive, and stop and wait if someone puts their car where you need to go when turning. (e.g. a car coming from the right pulling up to the light when you need the first 15 feet of that lane for turning right with a telephone pole on the corner.)
Old May 7, 2018 | 04:11 PM
Rd0g's Avatar
Rd0g
Since you already have the F-350 and are looking for a trailer, I would strongly suggest looking at a fifth wheel. No bumper pull will tow as nice as a fifth wheel and your F-350 will be able to tow all but the largest of fifth wheels. That being said, an F-350 can tow just about any bumper pull as well, I recently moved from a 2015 f150 to a 2017 f350 to tow my 28 foot bumper pull toy hauler and the difference is night and day between the added power and stability. What used to be white knuckle driving just about anywhere I went is now easy driving even in a good amount of wind or up a steep mountain pass.
Old May 7, 2018 | 06:09 PM
psdxohio's Avatar
psdxohio
Take the 3740 and subtract the weight of your “occupants n crap”. Be sure to include the weight of a 5th wheel or bumper pull WD hitch. Take that number that’s left over and divide by 0.13 for a bumper pull and 0.23 for a 5th wheel. That will tell you the max (use GVWR) trailer weight you can tow as far as the payload limitation. This is generally the limiting factor. However you still need to make sure you don’t exceed the max towing capacity and the combined (GCWR) truck and trailer capacity. And as others have said, the receiver hitch (bumper pull) or 5th wheel hitch will have weight ratings as well.
The bottom line is that you need to be mindful of 4 weights: hitch capacity, payload capacity, max tow capacity, and gross combined (GCWR) capacity. One of those will be the limiting factor and set the ceiling for your towing capability.
Old May 7, 2018 | 09:50 PM
rcorkum4's Avatar
rcorkum4
Tundra to F-350
I had the same issue with my 2008 Tundra and Rockwood 2703WF Ultralight. I was always bumping up against the Tundra payload limit and trailer max load. Now I move most of the heavy stuff from the trailer to the truck and am nowhere near maxing our the F-350 payload.
markag
All Things Towing
48
Nov 28, 2019 11:06 AM
ManO'War
All Things Towing
Jun 8, 2019 06:51 AM
Jayy
2015 - 2020 F150
43
Jun 29, 2018 03:34 PM
ecm2
All Things Towing
Sep 7, 2017 04:32 PM
trairider8
All Things Towing
Jul 21, 2003 04:22 PM
