Sponsored by: Kumho
8 lug ford wheel
Old May 4, 2018 | 05:24 PM
OldBlackCat's Avatar
OldBlackCat
8 lug ford wheel
I have aquired a 16" 8 lug, 8x6.5" bolt pattern steel wheel stamped ford and made by firestone?. Anyways it did not fit on the hub of my 95 ford van (tried for the giggles of it.... i allready have a spare for said van), center bore to small. Now im currious what did it fit? I measured the center bore and got 4.833" or 122.76mm
Old May 15, 2018 | 10:37 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Your question hasn’t been ignored. I’ve pondered it several times and pulled every paper catalog I have, and online reference I know, to figure it out. I, like you, thought the 16” F-250/350 and E-250/350 wheels would have the same center bore across those years. Your wheel is probably an Accu-ride/Accuride #28308 (the number will be there somewhere). It could be a #28378 that replaced #28308. Both are shown to have a center bore of 4.88”. You might measure yours again to see if you can find that fraction of difference.
My paper catalogs through the mid 1990s, and on-line Accuride catalog of 2011 still cite the 4.88” figure for trucks of your era although the wheels got wider and numbers changed. I have no reference to cite the hub bore dimensions of the mid 1990s vans. So I’m at a loss to explain why that wheel won’t fit your van. Stu
Old May 22, 2018 | 12:32 AM
OldBlackCat
stu,
thanks for the reply! yeah i got no idea whats up with this wheel. oh well
OEWheels-Tech
Appearance & Dress-Up
Feb 26, 2017 11:42 PM
Swiper
2009 - 2014 F150
May 6, 2016 07:01 AM
Herk100070
Large Truck
Mar 24, 2014 05:50 PM
sbowling79
Nov 17, 2012 01:41 PM
Rat77
Jan 10, 2012 12:59 PM
