tire size
Old Sep 18, 2003 | 08:54 PM
downdeephuskyjerk's Avatar
downdeephuskyjerk
tire size
whats is a good size tire for my truck? 93 4.9l 4x4 e4od 3.08 lwb. i believe it has stock tires on it now, they look small. i would like to go bigger of course but dont want to change the gears. just looking for a good all around size for my setup. i do some towing and hual fire wood and i also like to go about 90 on the highway.
Old Sep 18, 2003 | 09:14 PM
couleeman's Avatar
couleeman
tire size
I have 31x10.50x15 Bridgestones on mine. They look good and fit fine. I do notice if I turn to sharp, they will rub a bit though. I have the 3.08 with a 5 speed tranny. Not sure about the 90mph as the truck is getting a fair few miles on it and I don't want to push it.
Old Sep 19, 2003 | 05:23 AM
jarrod316's Avatar
jarrod316
tire size
i have a 95 f-150, 4x4 short bed, 4.9L , 5 Speed, 3.08 gears with 31x10.50 15 tires, stock tires were 235/75/15. speedometer changed by 4 mph. 131000 miles and i can still peg the speedometer all the way. only things i've done to the engine is changed the initial timing to 14 degrees btdc, and made a egr restrictor plate from a piece of 1/16" stainless steel plate and installed it. 31x10.50x15 tires are almost the same size as 265/75/15 which were available on some f-150's. 3.55 gears would be ideal for that size tire for towing in my opinion. but 3.08's can handle it as long as the load isn't to much.
by the way, nice truck couleeman!
809taino
May 26, 2024 02:03 PM
5280
Mar 25, 2017 12:37 PM
Leef250
Nov 10, 2016 06:07 PM
rlauer
Vehicles for Sale
Jul 31, 2015 07:38 PM
tastyklair
15
Jan 9, 2005 03:25 PM
