Help again!
Old May 3, 2018 | 10:11 AM
allentown09's Avatar
allentown09
Help again!
Ok I have a 1985 f250 with a 351w it has the factory motorcraft carb on it I believe it’s a 2150 correct me if I’m wrong please. Truck always ran fine strong engine no warning that I noticed I fired it up after work and it died on me the truck will not stay ideling now I have to keep the RPMs up once it get wamed up it will stay ideling but lags a lot of its power seems to have gone away I tried replacing the fuel filter, the choke does open up all the way when warm like it should and the jets in the carb are spraying out plenty hard. Just wondering if anyways has had similar problems and wondering what it maybe?
Thanks in advance for any and all advise!
Old May 3, 2018 | 01:16 PM
Franklin2's Avatar
Franklin2
Do you see liquid fuel dripping down in the engine when it's running and not moving the throttle?
Old May 3, 2018 | 01:32 PM
allentown09
Not that I have noticed
Old May 3, 2018 | 02:24 PM
1986F150six's Avatar
1986F150six
Check for vacuum leaks.
Old May 3, 2018 | 02:25 PM
allentown09
Ok will do thank you
Old May 3, 2018 | 06:51 PM
maytag906's Avatar
maytag906
EGR valve stuck?
allentown09
Sep 1, 2018 12:53 PM
dvideo22
1978 - 1996 Big Bronco
21
Jun 30, 2016 03:17 PM
Rocketdog2013
May 5, 2013 04:37 PM
goodwrench
General Automotive Discussion
17
Mar 8, 2005 11:06 AM
GendoIkari69
Feb 11, 2002 10:45 AM
