Got a noise. Hoping someone else has had it too
Over the past 5000 miles or so, I've developed a new noise. It sounds like a loose heat shield rattling. My trans dipstick tube was loose, so I temp zip tied it in place to make sure it wasn't rattling on anything. That didn't help. I can't find anything else loose.
Here's the specs. 01 7.3 420K. Can't hear the rattle or noise at idle, or with the hood popped and ranging through the rpms. Can't hear it under heavier acceleration. Mild acceleration, and or maintainin speed is where it's most prevelant. While driving, it sounds like it's more towad the passenger side. Is it possible that the EBPV is coming apart and rattling around??
If your sure it's not an internal issue, rather a down the road issue. Take a sledge hammer and nail each tire and listen for the rattle.
You have four chances to isolate the approximate location.
Grab your creeper and start from the nose and start hanging on everything that dangles. A broken exhaust clamp hangar will look good but if it's sheared, that would sound like you described. You might want to manhandle your exhaust outlet and see if you can shake the noise alive.
Denny
Denny
My experiences with cracked flex plates on other engines has been more of a knock than a rattle, but never heard a 7.3 with a crack. Try power braking stopped.
Also try getting on a down hill and coasting with the engine off to see if it's still there. Bang and tug on everything underneath, I'd start with the exhaust system. Some have a catalytic converter, those can rattle at different loads if the internals are busted, mufflers can do it too.
Well, something happened, and the noise started happening at idle. I grabbed my metal rod that I use for a redneck stethescope and climbed underneath. It reallt pissed me off (and made me happy) to find a loose exhaust pipe. I was under there days ago, shaking the crap out of the exhaust. I did the beat on the tires with the sledge to see if I could hear antyhing, and nothing. I must've hit a bump just right to knock it loose enough and stay loose. Thanks for all of the ideas. I'm just glad it's a $12 clamp versus pulling the trans.
