Parts to replace when pulling motor.
Old May 1, 2018 | 03:56 PM
notaduc's Avatar
notaduc
Hey folks,
Im in the midst of overhauling a 96 PSD; I will be pulling the body and motor to do rust repair and some other upkeep.
I have a new oil pan, welded some new oil jets, up pipes, down pipe, hoses belt etc. Wondering if anyone has tips for other parts that are easy to replace with the motor out.
Thanks in advance.
Old May 1, 2018 | 06:53 PM
farmert's Avatar
farmert
New orings in the oil cooler.
Old May 1, 2018 | 08:44 PM
oldbird1965's Avatar
oldbird1965
O rings on the fuel & oil plugs at the end of the heads. If the exhaust manifolds are leaking its a great time to pull them and machine them flat and put gaskets on them.
Old May 2, 2018 | 06:58 PM
notaduc's Avatar
notaduc
Awesome. Thanks for the replies.
Old May 2, 2018 | 09:01 PM
z31freakify's Avatar
z31freakify
Reseal the entire engine, only use approved sealant like TA-31 ftom Motorcraft to seal the oil pan and front timing cover. If your also rebuilding the engine make sure all O rings and seals are OEM or at least OEM approved.
Old May 3, 2018 | 04:31 PM
notaduc's Avatar
notaduc
Good call. Added to the list!
Truck only has 160k on it, not rebuilding, but will definitely reseal.
kegomatix
Jul 26, 2017 07:50 AM
aj197816134
Jan 24, 2016 06:52 PM
BigNick98
Jun 3, 2014 01:43 PM
sand_fiend
16
Nov 15, 2013 11:22 AM
poopey
Oil & Lubrication
26
Nov 27, 2002 07:04 AM
