Sponsored by: Real Truck
Stearing wheel shift
Old Apr 29, 2018 | 03:16 PM
Mpauly's Avatar
Mpauly
I have a 2012 F350 desiel with150k miles, a 3” read lift and 35” tires. When turning around on a highway median and hitting sum good bumps, the stearing wheel jumpt to about an 11 oclock position while the truck was driving straight. I got out and looked under the truck and could not find anything broken or loose. After hitting a few more bumps on a dirt road the stearing wheel was back in the correct position. Any idea what could be causing this? I am a little apprehensive about driving it. This is my daily driver so i would like to get it back on the road.
Old Apr 29, 2018 | 04:42 PM
DogRidesInBack's Avatar
DogRidesInBack
Ball joints, track bar, spring shackles/ubolts loose and shifting, ...
Old Apr 30, 2018 | 09:47 PM
RedTonka07's Avatar
RedTonka07
I think it is higher up
Pinch bolt on steering shaft connecting to power steering gear. If that is loose the wheel turns but the truck doesn’t.
EXv10
Nov 5, 2021 11:09 AM
greennwhite 77
Feb 10, 2010 09:26 AM
oem78
Dec 23, 2008 01:08 PM
MAYZ83
May 21, 2007 10:37 PM
Palomino
1997 - 2003 F150
Apr 4, 2007 12:44 PM
