Replacement tanks
Old Apr 26, 2018 | 09:00 AM
Afrnd2all's Avatar
Afrnd2all
Replacement tanks
I am pretty sure I have seen threads on this before, but cannot seem to find them. I am looking for information on replacement tanks for a 2017 f-250 diesel Extended cab, short bed. I prefer to replace the OEM tank and not a use an inbed tank. I met someone camping this past weekend who has the same tuck as mine except that its a '16. He had a ford dealership outside of Dallas who replaced a 29 Gal. with an after market 50 Gal. Any help would be appreciated, Thanks.
Old Apr 26, 2018 | 09:32 AM
Shreve T's Avatar
Shreve T
The company making the after market 50 gallon tanks goes by the name of Titan.. I'm looking into replacing mine with the Titan tank..
Old Apr 26, 2018 | 12:20 PM
jeffgreenx's Avatar
jeffgreenx
I just put a Titan 55 gallon tank in my truck a few weeks ago. Changed the distance to empty calibration on truck using Forscan. It's a mod you'll never regret. Filled up yesterday and it shows 660 miles to empty!
Old Apr 26, 2018 | 06:28 PM
34SF's Avatar
34SF
I have the Transfer Flow tank. Also did the recalibration with Forscan. Best and first mod.
Old Apr 26, 2018 | 09:15 PM
zman62's Avatar
zman62
I have the transferflow 60 gallon tank and love it.
Old Apr 26, 2018 | 09:24 PM
BigJoeT's Avatar
BigJoeT
Titan tank here for a while now. Working great.
Old Apr 27, 2018 | 12:34 AM
VA13FX4's Avatar
VA13FX4
TransferFlow and Titan are the two companies. Search for TransferFlow and you’ll find 2 big threads about the pros and cons of each. I just had the TransferFlow installed. I went with them because the price including install was about $200 cheaper.
Old Apr 27, 2018 | 08:05 AM
InkMing's Avatar
InkMing
What would folks offer up as cons of the bigger tanks? Curious to hear.
Old Apr 27, 2018 | 08:16 AM
harmanrk's Avatar
harmanrk
Cost. Weight (takes away from payload). Sticker shock at the pump (50 dollars twice does not seem as bad as 100 once)
Old Apr 27, 2018 | 08:25 AM
jeffgreenx's Avatar
jeffgreenx
The larger tank means no more OEM skid plate covering the stock tank. May not be an issue for most people. Although, the Titan tank is pretty much bullet proof. If I'm not traveling, I have to fill up like once a month, which is nice. Plus, if you are traveling (especially towing), you don't have to stop nearly as often to fill up, or navigate tight gas station setups with your trailer in tow.
I think after you get your head past dropping the coin to have it done, you'll never regret it. I never have.
Old Apr 27, 2018 | 08:30 AM
InkMing's Avatar
InkMing
Yep! So far those were the ones I had already taken into account when I have thought about it.
Old Apr 27, 2018 | 08:31 AM
InkMing's Avatar
InkMing
That is what would be my main push for it.
Old Apr 27, 2018 | 08:37 AM
Carbon8's Avatar
Carbon8
Titan 55 gallon, love that tank.
Would recommend the Titan for anyone living in the north with salt on the roads.
Old Apr 27, 2018 | 09:32 AM
bbronco66's Avatar
bbronco66
Went with the Titan 55 gallon tank and used Forscan to change the tank size. DTE will take some time to re-calibrate.
Old Apr 27, 2018 | 09:37 AM
zman62's Avatar
zman62
Transferflow makes a skid plate for the tank just like the factory. I love being able to go so far between fill ups
