Distributor
Old Apr 25, 2018 | 11:32 PM
frankbarnes's Avatar
frankbarnes
Distributor
hey guys, so i’ve town into my 5.0 95 f150 to rebuild my injectors. I pulled the distributor. It has a fairly new cap and button but the actual distributor has 230k miles on it. I also noticed some carbon or oil buildup on the block by the mating area. Truck runs as well as can be expected for that amount of miles. What should I look for on the distributor to decide if I should replace it? Can I rebuild? Thanks
Old Apr 25, 2018 | 11:35 PM
TexasGuy001's Avatar
TexasGuy001
Personally I would not replace an OEM distributor as long as it works good. An aftermarket replacement may not be as reliable.
Old Apr 26, 2018 | 10:37 AM
Scndsin's Avatar
Scndsin
You can put a Motorcraft PIP module in it after marking & driving out the roll pin.
Some can do it without a press, others can't.
I paid less than $20 to have mine done after putting engine to TDC pulling it myself.
You can pull the shutter wheel & clean it with a soft brush or compressed air too.
Old Jun 28, 2018 | 02:07 PM
dremtofford's Avatar
dremtofford
mine is covered in oxidation, think that might make it run a little rough?
Old Jun 28, 2018 | 02:35 PM
Conanski's Avatar
Conanski
No that won't make the slightest bit of diffrerence, just cosmetic.
Old Jun 28, 2018 | 02:36 PM
Scndsin's Avatar
Scndsin
Oxidation where?
djmichael24951
Feb 11, 2014 02:59 PM
AbandonedBronco
Jan 19, 2012 02:27 PM
go2toa
Aug 15, 2006 11:07 AM
kwieringo
Jan 17, 2002 12:37 AM
babybroncoii
Bronco II
Oct 29, 2001 03:31 PM
