Sponsored by: Real Truck
Water/Fuel Separator
Old Apr 25, 2018 | 12:51 PM
gadawg31's Avatar
gadawg31
Just finished changing out the water/fuel separator sensor and the dreaded "water in fuel" is popping back up again. Has anyone experienced this? I have read on several forums, including this about resetting; however I am not completely following on what everyone is talking about. Any info will be greatly appreciated.
2008 F250, 6.4L (EGR & DPF Deleted)
/r
JD
Old Apr 26, 2018 | 08:43 AM
speakerfritz's Avatar
speakerfritz
the reference is to clear the codes with an ODBC scan guage tool.
did you clean out the filter body?
Old Apr 26, 2018 | 09:59 AM
gadawg31's Avatar
gadawg31
I have not taken the entire HFCM off the vehicle, but I have replaced the filter twice in about a 30 day period. Did I miss something?
Old Apr 26, 2018 | 10:20 AM
speakerfritz
ive gotton false readings during/after winter due to gel accumulation in the fuel conditioning module.
this gel can be difficult to remove. I had to use a siphon pump on mine.
why did you need to change the filter twice in 30 days?????could there be gel in the fuel tank???
do you use anti gel additives during the winter?
Old Apr 26, 2018 | 01:30 PM
gadawg31's Avatar
gadawg31
The reason I changed the filter was someone told me that it could be getting dirty from the tank and causing the sensor to give a false reading. After the second filter change and the light still came on, I was told it was more than likely a bad sensor. When I took the old sensor out, it was really corroded and figured that was definitely the problem. Now that the light has come on again, I am at a loss for what it might be. Someone has suggested I might need to take the HFCM off the vehicle and tear it apart. Is this something I need to do?
Old Apr 30, 2018 | 11:53 AM
gadawg31's Avatar
gadawg31
Anyone else have any ideas?
Old May 2, 2018 | 07:25 AM
gadawg31's Avatar
gadawg31
Anyone, Anyone? Has anyone even taken the HFCM off to clean? There has to be more F250 guys on here than this? Need help with this please, before I spend several hundreds of dollars to replace. Can't afford a dealership, they want $986 to repair/replace.
Old May 2, 2018 | 08:06 AM
speakerfritz
the only cleaning adventure I had with mine was the drain being clogged. I put a pump on the drain and sucked the sludge out. Then it drained correctly.
Old May 2, 2018 | 08:57 AM
Evan_P's Avatar
Evan_P
You can buy the seals and gaskets needed to tear down, clean and rebuild the HFCM from Ford. Get the gaskets, pull the thing off the frame and take it apart to clean. If you find a huge buildup of debris in the HFCM you are going to need to drop the tank for cleaning.
Old May 2, 2018 | 09:20 AM
gadawg31's Avatar
gadawg31
speakerfritz, I was thinking of doing this; however I have read so much on here about putting air in the line and messing up the HPFP. Same goes for Evan P idea of rebuilding. Quick question: shouldn't my filter on the HFCM indicate a buildup of debris/sludge in the tank? I am hoping it just needs a good cleaning, not sure how complex of a job this is.
Old May 2, 2018 | 09:40 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The water drain is outside the filter, meaning the filter stopped the water so as it works it's way to the drain it brings debris with it. Doesn't always have to be a ton of sediment or junk to clog the WIF area, a tablespoon of less of dirt could eventually completely seal it off.
This thread is for the "similar" but not identical HFCM on a 6.0:
https://www.ford-trucks.com/forums/1...fuel-pump.html
Removal on yours is the same as the 6.0, it's once you get it on a bench and start opening it up that it's different.
This is a pretty typical "crud" build-up in the water trap/WIF sensor area (borrowed from another forum, you can find it via google image search):
Old May 2, 2018 | 09:44 AM
gadawg31's Avatar
gadawg31
Thanks texastech diesel. One other question then: would it hurt to take small about of air to blow back up thru the water drain, maybe just to see if something is blocking it? I just don't want to damage anything or put a lot of air in the line.
Old May 2, 2018 | 09:47 AM
texastech_diesel
Token Redneck
If you're having a recurring WIF light I'd think the debris issue is severe enough to warrant pulling and cleaning. Air might pop the drain open and let a little more out, but look at the build-up in there, that's not coming out with air. To get the pump out all it takes is disconnecting four fuel lines, removing three bolts, and one wire connector. If you ordered the seals ahead of time I'm thinking 2-3 hours tops to pull, clean, reintsall even if you've never done this before.
Food for thought: water is the death of the HFCM and common-rail injectors. Do you want to let a $10k fuel system ride on a cheap fix instead of putting in a Sunday afternoon worth of work?
Old May 2, 2018 | 09:53 AM
gadawg31's Avatar
gadawg31
Very true! Thanks for the advice. I believe a weekend project is in order. I may be picking your brain a little more when I get ready to bleed the system, if you don't mind. Thanks, JD
Old May 2, 2018 | 09:58 AM
texastech_diesel
Token Redneck
I'll try, but I'm a 6.0 guy, so I might be kind of limited to just helping with the pump. The procedure should be similar to after you change filters out, and sounds like you're up to speed on it, but a 6.4 guy will need to chime in to make sure I don't say anything dumb about the air bleed part of this.
