Adding OEM Skid Plates?
Old Apr 25, 2018 | 08:21 AM
disker's Avatar
disker
Just had the OEM skid plates put on my truck last Friday at a dealer. Cost was $960.00 for the shields and install (long bed with 48 gallon tank). It was the first one they did on a 2017 (they said) and it turned into more of a job they thought. They had to drop the fuel tank to get some of the hanging brackets attached. Transfer case shield is no big deal. But when they order in the parts for the install --each bolt and bracket has a part number and is not sold "as a kit". So it is a pain to order the required parts for the install. The fuel tank shield for the long box is very long!
Old Apr 25, 2018 | 08:23 AM
1956Fatfenders's Avatar
1956Fatfenders
I already have the fuel tank skid plate from another member who had upgraded their fuel tank.
What I 'd like to know is, what fasteners are required when adding the transfer case skid plate? Part number(s) are what I'm looking for.
Thanks in advance.
Old Apr 25, 2018 | 09:17 AM
undl8r's Avatar
undl8r
By chance do you remember what the labor and parts charges were?
Old Apr 25, 2018 | 09:18 AM
undl8r's Avatar
undl8r
Thanks in advance.
In post #11 I attached the parts diagrams for both long bed tank and x-fer case skid plate. It's minimal (x-fer case).
Old Apr 25, 2018 | 09:24 AM
undl8r's Avatar
undl8r
Originally Posted by VA13FX4
Here are some pictures. I thought the brackets were permanently attached because of the flat head bolts. Three of them are bolted on. The shortest one is riveted on.
Much appreciated.
Were you able to access the bracket bolts without dropping the tank? If so, I wonder if there's a difference between 34 and 48 G tanks. Were all the bolts attached to the frame? Disker wrote Ford had to drop his tank on a 48G.
Old Apr 25, 2018 | 09:55 AM
PentaPop's Avatar
PentaPop
When ordering the truck the skid plates were a $100 option while the wheel well liners were $325. For that price I expected the skid plates to be plastic but they actually look pretty stout. Seems they’re worth the dough.
Old Apr 25, 2018 | 10:45 AM
troverman's Avatar
troverman
Unless you plan on taking the truck off-road in rocky terrain, I cannot see how these skid plates are that valuable. My first 2017 did not have them and my second one (FX4) does have them. I will say the $100 option price is a bargain if you want them.
Old Apr 25, 2018 | 11:13 AM
dnewton3's Avatar
dnewton3
"Skid Plates" as Ford calls them are not really what many folks think they should be. I just think some folks expect too much.
Small rocks, branches, etc will be stopped by the "skid plates". They are not, repeat NOT, bash plates. They will not stop damage from your vehicle bashing down upon an object and puncturing a hole in something. If you are in 4x4 and crawling over small tree branches, or scuffing the underside of your truck while going up a creek bank, they work fine. The Ford skid plates are essentially a good way to keep small debris from kicking up and harming something. If you think that they will stop damage when the full weight of your truck heaves down as the front tires slip off some rock ledge, and the t-case or tank meets another boulder, you're mistaken. They were never intended or designed to stop all damage; just light forces.
I do see that they have value; road debris can often be stopped, or at least damage reduced, with the OEM skid plates. For an order option of $100 in stand-alone pricing; they're a good buy. Over the parts counter, they are a tad too pricey.
I am going to make my own plate for the t-case; I can fab one up far cheaper, and stronger, than OEM. The tank is a bit more of a challenge; odd angles and mounting make it more cumbersome. However for the crazy pricing of the tank plate and all it's little parts, I can be motivated to make my own. Buying a "used" tank plate is tenable; buying a Ford over-the-parts-counter is not.
Old Apr 25, 2018 | 11:20 AM
disker's Avatar
disker
Here is pricing and parts list for a 2017 F350 SD --long bed.
Old Apr 25, 2018 | 11:26 AM
troverman's Avatar
troverman
Skid plates are what you put on a Jeep, etc. to protect vulnerable underside components from damage while driving off-road. This means scraping over a rock or having at least a good portion of the vehicle's weight on them. If Ford's "skid plates" don't do this, they should be called something else. The plastic fuel tank is designed to deform in a collision, and realistically plenty of other things will break first besides the transfer case if you're off-roading. Light road debris is not going to damage the tank or the transfer case anyway.
Old Apr 25, 2018 | 11:33 AM
dnewton3's Avatar
dnewton3
The reason I make the distinction is because several years ago I was going up the Schaffer trail at Utah's Canyonlands NP, and there are many rock ledges that one has to negotiate. I saw a Ford SD truck coming down, and asked him how it was (as I was going up in my Dmax). He complained about the damage he incurred and we got underneath and saw his t-case plate bent upwards and in contact with the t-case itself (luckily not cracked or leaking). He said how he was disappointed in that the plate didn't stop the damage. My comment to him was as I described previously. The Ford OEM plates really are just debris shields; they are NOT designed and made to stop the full weight of a truck bashing down onto rocks.
It would be more appropriate for Ford to call them shields, but they don't. They call them "skid plates". And they certainly are not bash plates.
They are good at preventing some forms of damage; they are not going to stop all of it.
Old Apr 25, 2018 | 12:35 PM
troverman's Avatar
troverman
OK, I can agree with that. The fuel tank "skid plate" on a current-gen F-150 is made of plastic.
Old Apr 25, 2018 | 01:31 PM
  #28
HRTKD's Avatar
HRTKD
If you look at the parts list picture in post #24 the parts department does indeed call it a shield. Marketing did their thing and made it sound like more than it is by calling it a skid plate.
I specifically chose to not add the "skid" plates to my truck. I didn't want the extra weight or the expense. Sure, they're a steal if you order them from the factory. But I don't plan to be far off the beaten path with my truck.
Old Apr 25, 2018 | 01:38 PM
  #29
troverman's Avatar
troverman
Originally Posted by HRTKD
...I specifically chose to not add the "skid" plates to my truck. I didn't want the extra weight or the expense. Sure, they're a steal if you order them from the factory. But I don't plan to be far off the beaten path with my truck.
Jim, your avatar shows your old Titan driving through a river!
In reality, a Super Duty is not a great choice for off-road driving, anyway...given it's size and expensive aluminum bodywork. But they are surprisingly capable if you have the room to maneuver. Good ground clearance, very heavy duty axles, optional rear selectable locker, plenty of torque, and good suspension flex are combine to provide good capability.
Old Apr 25, 2018 | 02:02 PM
  #30
harmanrk's Avatar
harmanrk
I went with them as a 100 dollar add on, just for the bit of protection form road debris. Lots of tire remains on the roads around here.
