P0673
Old Apr 23, 2018 | 09:47 PM
arayray94's Avatar
arayray94
P0673
Any harm running with a bad glow plug? How soon do I need to fix it?
Old Apr 24, 2018 | 04:34 AM
Yahiko's Avatar
Yahiko
Glow plug #3 is reasonably easy to get at with only removing a few things. It should be the 2nd one back from the front of the engine on the passenger side.
Being an 04 I am not sure what glow plug power feed you have. As for running with it bad there is not much of an issue. It will start crapy unlit it gets some
heat built up. But I would not put it off too ;oe because you never know what that dead one is going to do.
Old Apr 24, 2018 | 08:30 AM
Mychael Bell's Avatar
Mychael Bell
you should really tell my lead this for real he will not change glow plugs he will not change em out or the harness say there is no need
Old Apr 24, 2018 | 09:34 AM
npccpartsman's Avatar
npccpartsman
If it's not starting hard then I wouldn't worry about it
Old Apr 24, 2018 | 10:31 AM
Mychael Bell
alot of these that I am talking bout does hard start or no start both I have usually noticed glow plug codes
Old Apr 24, 2018 | 01:41 PM
arayray94's Avatar
arayray94
It starts okay, I am sure getting some new ones in would help out alot. I just want to make sure the tip isn't going to break off or anything and do some major damage.
I've got the early style glow plug bus bars, do you use the same tool as 04.5-07 to pull them? Are they known for breaking like the newer ones?
Old Apr 25, 2018 | 01:58 PM
EMC V10 X's Avatar
EMC V10 X
You dont say where you are, I am in Florida and I never wait on the glow plugs with no issue. Like others have said, if it starts, then I wouldn't spend to much brain power or money on it....
6point0
Jan 27, 2018 05:30 PM
Willfredo
Feb 25, 2017 10:33 PM
Blakshukvw
Dec 17, 2016 03:37 PM
the_auto_tech
Aug 21, 2013 08:45 AM
sullyt28
Jul 27, 2010 07:38 PM
