Start of 54' build.
Received 4,135 Likes
on
That cross member is important and you still have enough of it to bolt one in. Without that cross member your frame will twist with the weight of the cab and when you step on the running boards..I cut mine out for easier access when removing the transmission and this works like a charm..
thanks for the reply.i assumed it was important. Is there any write ups on how to modify it like yours or pictures installed?
on
on
#29
I had the truck frame at 0 and they wanted the crossmember set to 2 degrees.now it's all at 0.idk if this will throw off suspension or not.guess I'll put it together and cycle suspension.
#30
on
