2001 7.3 Starter keeps cranking
Old Apr 23, 2018 | 05:46 PM
Nathaniel01's Avatar
Nathaniel01
Unhappy 2001 7.3 Starter keeps cranking
Hello to all you experts and gear heads,
I really could use your help fellas, I have a 2001 f350 7.3 powerstroke. The starter went out a few weeks ago and i ordered an aftermarket gear reduction starter hopeing for an upgrade for the old beast. To my surprise the starter continued to crank while the engine was running and when i shut it off. I figured it was the fender starter relay and i replaced it with a quality motorcraft one. The issue continued, so i purchased another starter, Ford brand this time. Instead of the starter trying to start the truck while it was running it decided to spin immediately(no key is present mind you), although it did not crank the engine. (Basically it just didn't engage, also the) I even tried to flip the power wires on the fender relay that come from the battery, same issue. Then i tried taking the smaller wire (it is part of the starter cable, and runs to the starter itself) off the starter, i touched the battery terminal and the same thing happened.
Old Apr 23, 2018 | 06:26 PM
dn29626's Avatar
dn29626
The starter motor ran without the starter drive engaging to contact the flywheel?
AllaboutMPG's Avatar
AllaboutMPG
Ignition switch could be stuck. check small wire to start relay for 12 volts. If present back track. wiring diagram attached to help
Old Apr 23, 2018 | 06:29 PM
Nathaniel01
yeah the ford starter did not engage it's just spinning but the other one did
Old Apr 23, 2018 | 06:30 PM
Nathaniel01
do you thing over tightening of the starter solinoid post could cause this
Old Apr 23, 2018 | 06:39 PM
AllaboutMPG
Could the starter solenoid be shorted internally in such a way it energizers the starter all the time. Guess anything is possible. Disconect all the wires from the fender relay and touch the battery cable to the battery again and if it happens then the starter is probably shorted internally.
If it doesn't spin hook fender relay back up and Try pulling fuse 20 and see if it keeps doing the same thing. If it does it's in the ignition circuit.
Old Apr 23, 2018 | 07:20 PM
Nathaniel01
Ok i disconnected the fender relay cables, all of them and the starter still spins...
Old Apr 23, 2018 | 08:30 PM
AllaboutMPG
Sure seems like the starter is shorted internally.
Old Apr 23, 2018 | 09:33 PM
Nathaniel01
its not the starter, and its not the ignition switch. could it be the clock spring or the ignition module?!?
Old Apr 24, 2018 | 06:31 AM
AllaboutMPG
If you took all the wires off the fender relay and the starter still spins then it doesn't have anything to do with the ignition circuit. The starter has battery positive hooked to it and uses the mounting surface as a ground. If the solenoid on the starter is stuck closed that's all you need to spin the starter.
Edit: never mind, was thinking old school solenoid
Old Apr 24, 2018 | 06:56 AM
Nathaniel01
I’ll buy a new one today and see if that’s it. Also if I hooked the battery lead up wrong where?
Old Apr 24, 2018 | 09:15 AM
Nathaniel01
I tried flipping the connections on the fender solenoid and the same thing happened. So I’m gonna test the wires at the starter for 12vDC when I get out of school.
Old Apr 24, 2018 | 09:56 AM
AllaboutMPG
never mind, was thinking old school solenoid with 2 wires
Old Apr 30, 2018 | 07:07 PM
Nathaniel01
i figured out my issue. im laughing now but i sure wasn't earlier. I had the wrong starter and the bendix was hitting the back of the fly wheel housing and grounding, therefor completing the circuit when i connected the battery cable. I simply took it back and got the correct one and no problem!
Old Apr 30, 2018 | 08:04 PM
AllaboutMPG
That's good news. Thanks for following up
m.collins
36
Apr 16, 2015 11:42 AM
droc9891
Jan 14, 2014 04:51 PM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
Sweetred95ta
Sep 20, 2006 04:41 PM
88blkranger
1983 - 2012 Ranger & B-Series
Dec 9, 2004 04:48 PM
