Is my 8BA engine scrap?
most likely is is .... at least I now have a guinea pig on which I can try a lot of shady treatments, like the good ole water glass in the water jackets, for instance.
Two weeks ago, I asked how to best put the head gaskets back on, pulled the heads because I found a few drops of coolant in the oil pan.
With the heads of, the cylinders have some ridge and have taper about 0.007 inch at the top. The decks have no cracks, not at the bolt holes and no cracked valve seats.
Pistons are still standard size 3,3/16. I was delighted, as a hone and ring job would be sufficient to do some driving around town before rebuilding. On closer inspection, the cylinders 4 and 8 have some severe wash out at small spots at the top. Narrow, but really deep. What the heck is this? The pits are orientated to the valves, at least not towards the exhaust manifold, where water or mouse pee would collect, if any got in for extended periods of time. OK, nothing which a rebore and two sleeves could not fix.
But after some more cleaning, I found another likely reason for the coolant drops: The engine maybe frozen some time, as I found a pan rail crack at the main bearing. Not gapingly large, but clearly there. Now I think it is not wise to throw big money at this block. The engine was running reasonably good before I took it apart to desludge it. I did not notice white water steam from the exhaust, at least. It had "some" blow by though, which I thought are sticky rings from sitting for ages.
A 1+1/2 hrs drive from me there is a guy with a 8BA block out of a F1 which supposedly is free of cracks. But it is 0.060 over already and was seized. The pistons were knocked out and there is a fair share of rust in the valve pockets. May be still worth a try to rebuild. In this part of the world, good blocks are hard to come by, although in cologne the g28t and g38t versions were build by the 1000's.
Wil
The crack in the pan rail is fatal, I'm afraid. You could pay a couple hundred bucks to have it stitched, but that's a very stressed area of the block. I bet if you strip all the paint off the outside of the block an inch or so above the pan rail, you'll find a nice long horizontal crack in the water jacket, too.
for your evaluation. No, there is no helicoil insert in the screw hole, but that particular screw unscrewed with just two fingers, LOL. I do not know when helicoils were invented, but .... this engine block was not touched in decades, judgeing from the amount of dirt, oil and rust it was evenly covererd in. It had two new water pumps instead and a new radiator. These are two more hints that the old rad and pumps maybe froze as well. When inspecting the truck, I did not look close enough and was carried away by the nice idle of the engine.
Regarding the cracks, all I did was visual inspection, and after finding the pan rail crack, I gave up in frustration to dig any deeper. I put the heads back on and pressurized the whole cylinder bank with a Schrader valve in the upper hose, in lack of proper pressure plates. I could not find any obvious leaks, the outer water jacket is intact.
Interesting, that panrail cracks apparently can be repaired. I thought nobody touches them with a 10ft pole. A (
But I'll do that after some other work. Right now, I need the truck running and moving, as I work alone and I simply cannot push it around the property just by myself. Thus, it will be running again pretty soon.
For the time being, I'll try to seal the engine block with ceramic seal = water glass or liqiud glass. The water jackets are clean and flushed with water anyway. This should buy me the time needed to find another block. God knows how long it did run this way - it definitely did. And if I can stop the minute water seepage into the oil, it will probably do a couple miles more. I hope it has not left for good yet.
