Was working on my F800 dump truck today and noticed on the driver side I have two broken leafs two down from the top.
I know that it is an Eaton rear end. but I need help knowing where to go or look for a new spring .
My VIN number for the truck is F82BVEH0303
WB 146
Type F822
Body 418
Trans 7
Axle GHM
Max GVWR Lbs 25500
DSO 47
Thanks for the print!
Might I ask how to derive a part number from it?
I have tried to look up the numbers 5560 (spring) 5705 ( U Bolt ) but not having any luck with those numbers. I think I need a little understanding.
