Sponsored by: Real Truck
Transfer case cracks
Old Apr 22, 2018 | 09:11 AM
DeeDubz's Avatar
DeeDubz
Crawled underneath my truck yesterday. I noticed some cracks on the transfer case. Is this normal? should I be concerned? Also does anyone know that part number for this seal. I need to replace it.
Thanks
Old Apr 22, 2018 | 09:46 AM
mapitts66's Avatar
mapitts66
Other than your seal in the last photo, those are very common in most aluminum castings. I am not sure of the alloy they cast with and I do not see oil leaking from them. You can always check them to see if they are cracks. If you want to do that let me know and I will tell you the correct way to do that.
Old Apr 22, 2018 | 04:38 PM
Highlife4me's Avatar
Highlife4me
Those are heat checks (cracks) in the mold that was used to make the casting. They are very common in die cast and permanent mold castings and do not weaken the casting at all.
frank washington
Mar 9, 2017 01:53 PM
Spankymeyer
May 5, 2016 03:03 AM
mrblonde108
Large Truck
Nov 15, 2011 06:05 PM
84 f250 6.9
Aug 23, 2009 12:18 PM
bigredkacy
Dec 23, 2007 07:00 PM
