Help!!
Old Apr 21, 2018 | 04:09 PM
Rcn1992 7.3idi's Avatar
Rcn1992 7.3idi
Help!!
Do I have to drain the oil to replace my mechanical fuel pump
Old Apr 21, 2018 | 04:28 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
Hello.
No you should be fine, but if the old pump your are changing was leaking diesel into the crank case then I would definitely change the oil and filter. If your oil level hasn't been rising by itself your probably good. Just try to keep any dirt and old gasket material from entering the crank case when you pull it and clean up the surface.
Good luck.
Old Apr 21, 2018 | 09:43 PM
genscripter's Avatar
genscripter
Crank case oil will not leak out if you pull your lift pump.
but as the previous guy said, change that oil if it got contaminated.
JMM-MD
Mar 3, 2013 06:04 AM
Redneckmorton
15
Jun 24, 2012 07:01 AM
ltl_jrw
Oct 12, 2009 04:36 PM
KRDiesel
Sep 9, 2009 04:17 PM
hotshothauler
Oil & Lubrication
Oct 15, 2005 10:33 AM
