Sponsored by: Auxito
2000 Transmission Issues
Old Apr 19, 2018 | 05:43 PM
Beldar's Avatar
Beldar
About 36k miles and 3 years ago, my 4R70W decided that reverse was the only gear it wanted to use. It had been acting up for about a while so I new it would eventually give up. I had the unit rebuilt then and over the past couple of months the transmission jerks randomly while going down the road usually around 45, 55 & 65 mph. It is more noticeable in high gear and overdrive.
Does the transmission need replacing or is it another issue?
2000 Ford F150 XLT Extended Cab
4.6L V8
Automatic Transmission
249,000 +/- miles
Old Apr 19, 2018 | 05:50 PM
Chad T. Keogh's Avatar
Chad T. Keogh
I would check all the electrical connectors that were disturbed during the replacement first. Could be a simple fix...
Old Apr 19, 2018 | 06:02 PM
Rjdunshee's Avatar
Rjdunshee
Could also be a misfire or if it’s real fast like your running over city bumps then torque converter shudder.
Old Apr 19, 2018 | 09:23 PM
Beldar's Avatar
Beldar
I just put new plugs and coil packs in it so hopefully that's not the issue.
Old Apr 19, 2018 | 09:32 PM
Bluegrass 7's Avatar
Bluegrass 7
Note the following;
Does it still do the same out of OD or down shifted with increased engine RPM?
If no, you have a faulty coil on one cylinder.
If yes, it's something else.
To find out, use a Scanner to look at mode 6, test 53.
There you will see the misfire counts for each cylinder.
If one cylinder is high, it's coil is suspect.
You will not see a code generated for this kind of fault so you need this way to detect which cylinder is the cause.
Otherwise use a Scanner set up to trap and freeze the data for the cause area.
Good luck.
underthebridgejim
44
May 25, 2013 11:49 PM
Dave O'Brien
May 10, 2012 05:30 PM
FlatBlak
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 20, 2012 04:49 PM
fmjnax08
1997 - 2003 F150
Mar 6, 2011 08:23 PM
