Sponsored by: Auxito
Drivers side CV joint axle
Old Apr 19, 2018 | 05:15 AM
96f150's Avatar
96f150
According to the book, you have to remove the upper and lower ball joints to get the cv axle out.....Is this entirely true? It looks like if you just unbolt the inner flange, you should be able to swing it out of the way and just pull it out the backside. I have to replace my drivers side because of a slight tear in the boot that ive been fighhting
Old Apr 19, 2018 | 07:45 AM
miked79928's Avatar
miked79928
You do not have to remove any ball joints to get it out. I have done several and all I ever remove is the shock for clearance.
Old Apr 19, 2018 | 03:45 PM
96f150's Avatar
96f150
...Thats awesome! Ive got a small hole in it, that ive patched a few times, so i have to replace the boot....The joint on both ends is still good
Old May 1, 2018 | 07:47 PM
96f150's Avatar
96f150
Miked79928..........what did you use for a boot? I want to get one thats gonna last...
Old May 2, 2018 | 11:13 PM
miked79928's Avatar
miked79928
I replaced the whole CV axle, so it came with a new boot.
Old Mar 23, 2021 | 05:00 PM
tangster's Avatar
tangster
that what I've seen just the 4 nuts on the hub get removed for 05 like mine and up 04 down is said to be doable also just tighter soot for socket to get at stud nuts.
keyul
Nov 2, 2014 06:28 AM
jeter
Jan 29, 2010 05:53 AM
68-F250-4x4
Apr 7, 2008 07:57 PM
fordberg
Sep 6, 2004 11:07 PM
broncopimpservice
Bronco II
Apr 13, 2002 09:57 AM
