Codes, need help
Old Apr 19, 2018 | 03:21 AM
Clay Hitchcock's Avatar
Clay Hitchcock
Codes, need help
Can someone possibly tell me what's wrong with my 2010 v6 Ford escape. Once car is warmed up then it's shut off and restarted check engine light comes on and runs poor, rough idling and while driving it runs bad and shakes car. The codes that come up are p0301(cylinder 1 misfire) p0201(cylinder 1 injector open) p0443(evaporative emissions system purge control valve circuit). I already took out cylinder 1 injector tested for ohms was at 12, cleaned out injector appeared clogged at first.
Old Apr 19, 2018 | 04:03 AM
David7.3's Avatar
David7.3
Purge valves go bad alot, and if they stick open it can cause and vacuum leak and will lean out the cylinder. I would start by changing the valve or the they usually come from ford complete with canister and valve, maybe even with lines because they had so manyproblems. reset the codes and drive her she if that made a difference in the miss fire code as well.
Old Apr 20, 2018 | 12:47 PM
Clay Hitchcock
I changed the purge valve, that took away the p0443 code, the other ones are still up and same symptoms.
Clay Hitchcock
Apr 18, 2018 12:21 PM
bkuuz1
Dec 3, 2013 03:33 PM
JaySVX
Mar 30, 2011 08:50 PM
Eaglefixer
1983 - 2012 Ranger & B-Series
Jul 6, 2010 08:22 AM
racingtom
Apr 4, 2007 05:50 PM
