Sponsored by: Auxito
driver window problem
Old Sep 18, 2003 | 09:04 AM
spongebrad's Avatar
spongebrad
Angry driver window problem
This is my first time here. But this is the problem. Driver side window will not operate. Short has been diagnosed. The ford place says its a relay but will not tell where that relay is. Anyone that can tell me what relay and where it is would be greatly appreciated.
Thanks
spongebrad
Old Sep 18, 2003 | 09:43 AM
LxMan1's Avatar
LxMan1
I think it is under the dash, that's where the click comes from when I use mine.
I would check to see if the window motor is going to ground first.
Jimmy
Old Sep 18, 2003 | 07:53 PM
VARNEY1's Avatar
VARNEY1
i think i can give you some direction. just as with alot of the realys under-hood, they have combined relays in the pass. compartment. it is called the generic eletronic module. it controls your windows, some of your headlight functions, and a few other misc. functions.
Old Sep 19, 2003 | 10:43 AM
spongebrad's Avatar
spongebrad
Thanks guys,
I found the culprit and its fixed. You saved me. I will definitely come back here again to help and get help.
