4 wheel drive
Old Apr 17, 2018 | 07:06 AM
Duke Judy's Avatar
Duke Judy
4 wheel drive
My 2017 F250 4 wheel drive will not disengage unless I stop and back up. The dealer is saying its a vacuum and that's normal. Does anyone have this problem?
Old Apr 17, 2018 | 07:35 AM
Bovinerazzr's Avatar
Bovinerazzr
Normal. Backing up let's the drivetrain relax and allows for disengagement.
Old Apr 17, 2018 | 07:43 AM
VA13FX4's Avatar
VA13FX4
No, that is not normal. Not on my 17 anyways. I’ve used 4wd dozens of times and I never stop to shift in or out. Definitely don’t have to go to reverse. Show the dealership the user manual where it talks about 4wd and ask them to show where it says going into reverse is part of the process.
Wondering if you have have your hubs in manual though instead of auto?
Old Apr 17, 2018 | 07:44 AM
troverman's Avatar
troverman
I would say NOT normal. I can shift in and out of 4x4 all day and it will promptly shift in and out. Sometimes it delays for a few seconds coming out, but then it is done.
When the transfer case disconnects, you are definitely in 2WD even if the hubs take a few more seconds to disengage. Do you have the electronic **** shifter (ESOF) or the manual floor shifter?
Old Apr 17, 2018 | 08:14 AM
K A M's Avatar
K A M
Not normal. The system is in a bind and can't pull out. Check your hubs to see if they are in AUTO but should still go in 2H even with hubs locked. Air pressure in tires at normal, same size tires?
Old Apr 17, 2018 | 08:36 AM
VA13FX4's Avatar
VA13FX4
Do you have to come to a full stop and go into reverse every time? Or did it happen one time?
Old Apr 17, 2018 | 08:43 AM
Buliwyf's Avatar
Buliwyf
The hubs are unrelated. Those can stay stuck engaged as long as they like. They'll rattle loose when they want to, complete non-issue.
I'm guessing your problem is selecting 2wd, and the 4wd light on the dash stays on too long. But how long is too long?
If you've been turning in high grip conditions, then your drive train is bound up. You'll need to drive straight, bounce around, or reverse to get unbound. When the dirveline gets twisted up from turning, it's like a big spring, or a big lock washer, and things get stuck.
If you drive slowly, in 2wd. Driving in a perfectly straight line. How does it shift then? Is it faster. It should only take a few seconds.
Have you been using 4wd every week? You have to exercise the system from time to time. It's fine even on pavement AS LONG AS YOU'RE DRIVING IN A STRAIGHT LINE. Slow is nice, if your hubs aren't locked.
Old Apr 17, 2018 | 10:05 AM
tony m 6.7's Avatar
tony m 6.7
I don't believe that backing up is normal to disengage the 4wd, but if the system was bound up for some reason, backing up would help relieve the strain or slight bind on the drivetrain. I remember having to backup once with my 2012 after using it to get out of a muddy parking area where I was turning the truck to get out in a small amount of space. Otherwise, my 2012 and my 2017 have both normally shifted out of 4wd on the fly.
Old Apr 17, 2018 | 04:50 PM
BronzefireAL13SD's Avatar
BronzefireAL13SD
The rep at the dealer probably drove to work in his Ford fiesta....
crazymut
Apr 26, 2015 01:48 PM
ghunt
Jul 6, 2008 05:01 PM
my96f150
Offroad & 4x4
13
Jan 8, 2005 07:37 PM
teepee542
Offroad & 4x4
Jun 23, 2004 10:08 AM
Jimmy Dean
Offroad & 4x4
Aug 20, 2003 10:08 PM
