Sponsored by: Real Truck
No 4lo
Old Oct 3, 2014 | 01:37 PM
crazymut's Avatar
crazymut
No 4lo
When I shift into 4Lo I get no 4 wheel drive. 4Hi works. Did have a/c redirect to defrost a couple of times. I remember something about the air redirecting having something to do with not having 4x4 but don't know just what it was.
Old Oct 3, 2014 | 01:39 PM
JM96F250's Avatar
JM96F250
Year and model?
Manual shifter or Shift on the Fly?
Old Oct 3, 2014 | 01:40 PM
seville009's Avatar
seville009
I think it's all or none if it's a vacuum issue.
Did you have it in neutral when you tried to go into 4lo? You need to. Sometimes it takes a few seconds.
Old Oct 3, 2014 | 01:52 PM
JM96F250's Avatar
JM96F250
Yea, that's why I asked. Is it a manual shifter and just not shifting. Or are you shifting and front wheels aren't turning (are your hubs locked?)?
Shift on the fly, I have no idea on what is involved with that system.
Old Oct 3, 2014 | 02:01 PM
crazymut's Avatar
crazymut
It's a 2001, auto,shift on the fly. Stopped in neutral waited and nothing. Don't even get the "low range" indicator light. 4 hi worked just not 4 lo.
Old Oct 3, 2014 | 02:07 PM
JM96F250's Avatar
JM96F250
Someone else will have to fill him in. I have no idea how those systems work.
Old Oct 3, 2014 | 02:10 PM
Paso1's Avatar
Paso1
Mine has to be in neutral and foot on brake before it will engage
Old Oct 3, 2014 | 02:56 PM
crazymut's Avatar
crazymut
I always stop, apply brake, put in neutral, and then select ether hi or low range, wait for actuation and go on my way. With low range it just would not engage, it went back to two wheel drive.
Old Apr 26, 2015 | 01:48 PM
crazymut's Avatar
crazymut
Found the problem. At the tranny there a shifting unit attached to the tranny. Where this unit attaches to the shaft there is as alignment mark on the shaft and another on the shifter. These marks were about 1/32 inch from lining up. Adjusted shifter and all is good now. Even my reverse lights work normally now.
delorenzomp
Aug 22, 2018 08:15 PM
bishopgeer
Oct 2, 2010 10:50 AM
wickedwindsor
1978 - 1996 Big Bronco
Feb 2, 2010 04:29 PM
Big Sky Rancher
Apr 1, 2007 12:43 PM
pwrstrk
Nov 7, 2004 06:59 PM
