Would this Snap On MT2500 set up work
Old Apr 16, 2018 | 02:09 PM
Nathan7.3's Avatar
Nathan7.3
Hi I've got a 1995 f250 7.3 manual trans with a check engine light on and I want to buy a scanner instead of paying a shop to scan it. I found this scanner and owner of the tool said that it will work for scanning my truck with what is already provided but from what I've seen, I need the ford cartridge. The kit comes with both OBD1 and OBD2 adaptors. Could someone clarify if this will work or if I need to buy any other adaptor or cartridges. Thanks
https://youngstown.craigslist.org/tl...547781506.html
Old Apr 16, 2018 | 03:32 PM
knottyrope's Avatar
knottyrope
with an android device
buy a scanner to monitor your engine
https://www.amazon.com/Vgate-Bluetooth-Scanner-TORQUE-ANDROID/dp/B00AAOOQJC/ref=sr_1_1?ie=UTF8&qid=1473776759&sr=8-1&keywords=vgate+OBD2 https://www.amazon.com/Vgate-Bluetooth-Scanner-TORQUE-ANDROID/dp/B00AAOOQJC/ref=sr_1_1?ie=UTF8&qid=1473776759&sr=8-1&keywords=vgate+OBD2
Torque Pro
https://play.google.com/store/apps/d...g.prowl.torque
Use the communication in the profile
SAE J1850-PWM
make sure you add in Ford PIDs
https://play.google.com/store/apps/d...ch.CarGaugePro
people like it cause it will pull codes, buzz test and CCT
Warning, Some OLD PCM's have to be flashed before you can pull codes
This is what I use on my F350
Old Apr 16, 2018 | 08:14 PM
Nathan7.3's Avatar
Nathan7.3
I would do that but I have a iPhone. That's why I was wondering about the scanner.
Old Apr 16, 2018 | 09:01 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
I just bought the aeroforce interceptor for my 2001 but it will work on all 94.5-2003 7.3's. it's $250 for one or $400 for 2. It can read and clear codes, injector buzz tests, cylinder contribution, and much much more. Well worth the price. I have seen it in action and my buddy used his on my 97 F250 a few months ago.
Old Apr 19, 2018 | 10:37 AM
paintubturner's Avatar
paintubturner
Did you buy the scanner?
Old Apr 19, 2018 | 11:00 AM
knottyrope's Avatar
knottyrope
cheap android devices are under 50 bucks now
Old Jun 18, 2018 | 12:15 PM
Nathan7.3's Avatar
Nathan7.3
I was wondering, what devices should I look for used. I don't know anything about phones and have no idea what im looking for. I would like to get a cheap used phone to use the app to scan my truck. The only thing I would need the phone for is just to scan the truck. Thanks
Steven99
North Carolina Chapter
Mar 18, 2016 08:19 AM
NovaNewfie
1997 - 2003 F150
15
May 2, 2014 01:24 PM
jayc3169
Mar 15, 2011 09:09 PM
dryfly
Dec 16, 2007 05:43 PM
PatN
Apr 9, 2006 01:08 PM
