Advise needed! Injectors, torque converter, ect.
Time to work on the truck.
1. My torque converter is giving me problems when towing heavy. It throws a code and won't lockup. Can't remember the code though. So thinking new converter, which one do I choose? What's the best source? Should I replace the pump while I'm in there? Planning on upgrading the pan to a 6.4.
2. I have an injector or two that are sticking when cold. Its not giving me a code. Do I replace them all? It gave me a cylinder last summer but hasn't since, and I forgot what it said as we were on vacation and cleared it. Where do I get replacements? Whats the best option? Thinking of upgrading to larger and doing fuel system upgrades. If i go this route, where is my best source?
3. Gonna replace head gaskets, getting pressure in coolant. must be a pinhole somewhere. Went with the black diamond gaskets when I bulletproofed, been 80K miles. Going with ford this time. What else should I do while in there. Thinking of going external oil cooler and filter while I'm at it. What else?
About the truck. I did a all the bulletproof stuff about 80K miles ago. Sinister diesel full kit. EGR deleted. straight piped. FICM.com hercules tune. SCT tuner. Did all this about 5 years ago and this place was a huge help. Truck has about 191,000 miles currently.
It's not a shifting problem. It will probably wait till after the other items are done anyway. But it all has to be done in a month, so need to get everything ordered.
Autonation in White Bear Lake, MN or ficmrepair.com are your best bet for pricing.
If you are going for serious power then you might look at Warren Diesel
Casserly injectors (Full Force Diesel) are good (two-year warranty). Lots of folks like Holders Diesel injectors also (3 year/100k mile warranty).
https://shop.fullforcediesel.com/6-0-powerstroke-performance-parts-s/109.htm
https://shop.fullforcediesel.com/motorcraft-injectors-set-p/4c3z-9e527-brm-6.0.htm
Holders Diesel
http://holdersdiesel.com/product_info.php?cPath=3_18_80_580&products_id=142 2
Holders Diesel
TheBlueMule
01-24-2016 04:51 PM
msmenne17
04-13-2012 02:23 PM
