*HOW TO* Installing Factory Door Keypad on 2017+ Super Duty
This worked awesome! Did this on a friends new 18 F450. He had his body guy (runs a repair shop) physically install the keypad and I did the FORScan work. His truck doesn't have Sync 3, just the basic small radio screen. The APIM line change did not add the ability to change the code, is there a change that allows the ability to change the code on a non touchscreen System? Otherwise he will just have to learn the OEM door code! Thanks!!
The following users liked this post:
Originally Posted by h20camper
You can't change the OEM code but you can add up to five additional codes. From the owner's manual.
What happened to the pictures? I am trying to ID the connector inside the door, and I thought i recalled seeing a pix of the connector. I took my door panels off, and I have a connector that is dead-ended that sits about mid-door, behind the glass, on a horizontal support rail. The connector seems to have a plug cover on it (makes sense as it's not used currently). It has 5 small wires; black, brown, blue, purple, green (hard to tell with poor lighting and behind the glass). Is that the keypad connector lead?
Do you have to temporarily raise the glass to connect the leads together? Then lower it back down to put everything back upon reassembly I presume?
https://www.ford-trucks.com/forums/1...ode-on-xl.html
Yes, that sounds like the right connector. See posts #11 and #14 and the attached pdfs in the post of this thread.
That looks very similar to what I have. I found that harness terminated right about that same spot. I guess I didn't realize how long the pig-tail on the keypad must be to reach all the way down there; it must be 20" or so?
Because I have the factory power equipment group, I do have power windows and power door locks, and so that harness plug is present, but unused (for now) inside the door panel.
Quick sidebar question about ForScan connectivity; I see from other threads that most folks mention using the BlueTooth MX connector, but it's like $80. There are some corded OBD connectors capable of doing MS-CAN that are only $30. I presume a corded version will work just as well? I don't need both, right?
Ok now my ignorance is shining like the bright mid-day sun in Death Valley ...
What's the purpose of switching between MS and HS? Is that something I have to do during the programming sequences? Or does it get set once and then left alone?
Uggggghhhhh .... my kingdom for a simple process!
Some of the 'cheaper' adapters have a toggle switch to switch between the MS and HS bus. From a FORScan post.
Also, important note about adapters with mechanical HS/MS switch: in addition to the fact it is not very convenient to switch it manually, it may be not possible to perform some operations with this type of adapter. If some operation requires a simultaneous access to both HS and MS (so FORScan needs to access some module(s) on HS CAN bus and, at the same time, other modules on MS-CAN bus), it cannot be normally executed using adapters with mechanical switch. Example: reading parameters (PIDs) in virtual module All, Module initialization subfunction in service functions "Remote keyless entry and Start".
#28
What's the purpose of switching between MS and HS? Is that something I have to do during the programming sequences? Or does it get set once and then left along?
#29
I have zero interest in using a cell phone app to track live data, etc. Hence, I really don't know that I need/want a BT OBD device.
All I want is to program stuff like the turn signal blinker count (SCCM module), steering wheel audio controls (SCCM module) and the door keypad enable (BCM module).
As far as I can tell, there's no "need" for me to get a BT unit, is there?
I've watched some YT videos and it seems like the corded units with switches do work, albeit not automatically. I noticed that the as long as you properly configure the ForScan tool to know that you have a switchable link, it will prompt you to switch that communication speed circuit depending upon module selected for alteration. Several times in this video example, the guy switches the comm port speed, when prompted by ForScan, because he set up the ForScan parameter to acknowledge a manually switched device.
In this vid, you can see how to set up the manually switched com port
I just don't want to spend $80 if I can spend $30 to get the same net result.
