EGT Issue
Old Apr 15, 2018 | 01:21 PM
Markus Luukko's Avatar
Markus Luukko
EGT Issue
Recently I put a 66mm compressor housing and WWII on, well the EGTs are higher than I anticipated and typically reach 1000 degrees quickly. When I’m unloaded the fuel economy tune and daily driver tune is hotter than the all out race tunes. When towing my 4500lb boat and trailer combo, the EGTs reach 1000 degrees in the tow tune. I have a ZF6 with a 5 inch exhaust and 6637 intake. I know my up pipes are leaking but I’m not convinced that fixing he uppipes will fix my issue, I was looking into getting a 1.0 AR exhaust housing as well, but I don’t want a laggy turbo. I make 25lbs of boost max and am not sure if I have a boost leak, I got 18 MPG over a 400 mile trip so I doubt I do but I could be wrong.
Old Apr 15, 2018 | 02:25 PM
z31freakify's Avatar
z31freakify
I told you in your other post to not put the 66mm wheel without re-tuning you will run high egt's, and if you install the 1.00 exhaust housing it will make it worst. Fix those leaking up pipes, the samllest leak can cause higher EGT and low boost numbers.
Old Apr 15, 2018 | 02:43 PM
Markus Luukko
First off I spoke to Brian Jelich, the guy with the fastest 7.3 in the world and the guy who writes my tunes and he said I don’t need different tunes for this turbo. And yes I was wondering if doing the up pipes would make a significant change to my EGT numbers cause I’d rather not have a bigger exhaust housing.
Old Apr 15, 2018 | 02:58 PM
Bonanza35's Avatar
Bonanza35
Nothing wrong with 1000 EGT. You can run there all day long. But if you have leaks, fix them. No way a tow tune should have higher EGT's then a race tune. Something wrong there.
Old Apr 15, 2018 | 05:47 PM
z31freakify
Look at my sig this is how I know it didnt work lol.... But yes fix those up pipe leaks you will be surprised how much of a difference it will make on the EGT department and boost.
Old Apr 15, 2018 | 05:52 PM
Markus Luukko
Can’t see sigs on my phone, but I found the main boost leak, spider to the turbo wasn’t aligned right. Gonna be ordering up pipes tonight, just need this to last until I get an engineering job in a couple years then I’ll get a t4 set up and pull the engine
Old Apr 15, 2018 | 06:01 PM
Markus Luukko
Not the tow tune but the fuel economy and Daily driver tune, but yeah doesn’t make sense to me. Maybe because with the highest tune you need less fuel to keep up with the speed you’re at?
Old Apr 15, 2018 | 06:59 PM
z31freakify
Nice, cant beat a t/4 set up. They are hiring Mechanical engineers on my area, theres a shortage of you guys over here.
Old Apr 15, 2018 | 07:04 PM
Dan V's Avatar
Dan V
First off, I ran his set-up, 160/30 , with a 1.00 ex housing. The EGTs were easily lower than the GTP38 in stock config. I will agree with fixing any drive pressure leaks as that D66 is big and takes a lot of power to drive it with the stock GTP38 ex turbine.
Old Apr 15, 2018 | 08:10 PM
Markus Luukko
And where is that lol, I’m in my 2nd year of college so next year I should be able to get a paid internship. Now I am pretty sure I got the up pipe collector seated to the back of the turbo correctly, but it seemed too easy for me as everyone online said it’s a PITA to get on. I’d suspect if there was a leak there, that there would be soot on my turbo and the band clamp wouldn’t sit properly. But having that be off would make sense for my EGT issue, idk I’ll get it eventually.
Old Apr 16, 2018 | 07:41 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Adam (z31freakify) has a location marked as Las Cruces New Mexico. Not sure if you are using your phone or tablet and you may or may not be able to see the posters location on that platform.
Adam is a great source of knowledge on the 7.3, but his color choices are questionable at times. I'll end it with this, don't **** off your mechanic, especially when he is replacing an engine for you...
Old Apr 16, 2018 | 07:41 PM
z31freakify
El paso TX., Alburquerque, Las Cruces area, I wont post Company names but look jobs in these areas.
Hey now Sous these are just engine colors not truck colors lol..... And the pissing the mechanic of I think it was another member cant remember who.
Old Apr 17, 2018 | 07:09 AM
Sous's Avatar
Sous
FTE Emeritus
You sure Adam? I could have sworn you painted an engine pink before putting it back in the truck?
Old Apr 17, 2018 | 07:19 AM
timmyboy76's Avatar
timmyboy76
Yo Sous..think that was SnakeDoc lol. Winger where the batchvof them went...him, bigdogcuzz, shakebake..just to name a few. they were a wealth of knowledge around here
Old Apr 17, 2018 | 09:48 AM
Sous's Avatar
Sous
FTE Emeritus
Dangit... Now you fellas are making me question my own sanity, which happens a lot really.
Going to look for the post... I'll be back...
EDIT: Found it...
https://www.ford-trucks.com/forums/1...-mechanic.html
You were right, my apologies for thinking you had a fetish with pink engines. Coincidentally, the poster is on the opposite part of the country as you Adam.
OP: Sorry for the off topic rant.
