Sponsored by: Auxito
Smog pump elimination
Old Apr 15, 2018 | 10:48 AM
Bostonwindows30's Avatar
Bostonwindows30
I have 1988 f-150 300 4.9 Truck I am rebuilding I want to eliminate the smog pump, what the best way to do so? Shorter belt or bracket? Where can I fine either??
Old Apr 15, 2018 | 10:56 AM
David7.3's Avatar
David7.3
Shorter belt you can find any parts house, remove the pump wrap 3/8 ths rope around everything and measure at the middle of the adjustment slot. Belts are measured in MM and the diam. 7 is thinner than a 9.
Old Apr 18, 2018 | 12:16 AM
Bostonwindows30
Thanks, but really looking to see if anyone has done this, and what belt to use.
Old Apr 18, 2018 | 06:16 PM
steve(ill)'s Avatar
steve(ill)
well, your asking a question about a 1988 truck on a 2003 truck site. Probably not the best place to get a belt size... Still the BEST option is to take an old belt or rope and cut it and fit around the pulleys, then measure it and buy a new belt.
Old Aug 13, 2019 | 09:29 PM
robinc2's Avatar
robinc2
Ford 300 cu in 6 cyl smog pump removal
i have a 1989 truck i took the serpentine pulleys off of to convert the 1966 F100 motor from V-belts to serpentine belts. i got everything done. i need a pully to replace the smog pump. Anyone know where to get this part?
Old Aug 14, 2019 | 08:50 AM
steve(ill)'s Avatar
steve(ill)
your going to have to go to Auto Zone or other and just ask to see a variety of pulleys and see what you can make fit .... or go to the local scrap / truck yard and just do some inspections.... There is nowhere to "look it up" on what your doing.
I assume you are DELEATING the smog pump and just want to put an IDLER in its position ? Why not go to Auto Store and ask for a generic IDLER PULLEY/ Bearing for a truck.... your going to have to build a bracket to mount it.
Old Aug 14, 2019 | 08:54 AM
steve(ill)'s Avatar
steve(ill)
https://www.ebay.com/itm/Drive-Belt-Idler-Pulley-Fits-97-03-Ford-F-150-E-550-Super-Duty-419-637/283045279031?fits=Year%3A2000%7CModel%3AF-150&epid=238723183&hash=item41e6d03537:gywAAOSwN 6NbQRR~
Or how about ripping all the guts out of the smog pump, just running the shaft and bearings in an empty case... then mounting a new pulley onto the shaft ? Still may need a little machining on pulley... but it would not need a bearing.
myakkacracka
Mar 23, 2015 10:56 AM
baddad457
Jun 2, 2012 01:56 PM
Bennyboy2002
Feb 28, 2011 06:35 PM
meck1
May 13, 2007 08:09 PM
rsmack
Aug 24, 2004 03:23 PM
