Sponsored by: Real Truck
High beams won’t work
Old Apr 14, 2018 | 05:32 PM
Outlaw_bam's Avatar
Outlaw_bam
so, I got new headlight for my f350, as I was checking to see if the light worked my high beams stopped working, I already checked the fuses and I have no blown fuse, I don’t know what else to do so I’m coming on here asking for help to figure it out
Old Apr 15, 2018 | 10:09 AM
alloro's Avatar
alloro
Did you try flipping the headlight hi/low beam switch a couple of times?
Old Apr 15, 2018 | 11:50 AM
Outlaw_bam's Avatar
Outlaw_bam
Ya I did, when I put my headlight switch on the blue indicator won’t turn on either
Old Apr 15, 2018 | 12:12 PM
projectSHO89's Avatar
projectSHO89
It would probably help if you supplied needed information, like what year you're working on, or what you actually did/installed. BE SPECIFIC.
Old Apr 15, 2018 | 12:17 PM
Outlaw_bam's Avatar
Outlaw_bam
Ok, so I have a 2004 Ford F-350 that has two piece headlights stock, well I hated that look so I got one piece headlights that have a high beam and low beam build well before I put everything together I made sure that my led bulb worked and the my hid bulb worked, they both did so I put everything together and headlights went on, well as soon as I check my high beams the blue indicator wouldn’t pop up on my dash, and it would kill my low beams
Old Apr 15, 2018 | 02:18 PM
99f350sd's Avatar
99f350sd
Something wired wrong sounds like..or hi beam fuse
Old Apr 15, 2018 | 03:21 PM
Outlaw_bam's Avatar
Outlaw_bam
See I suspected that too, but there was no way the wiring was messed up I didn’t mess with any of the wiring
kupiec20
Dec 21, 2013 05:18 PM
highteckredneck
1997 - 2003 F150
May 19, 2010 01:55 PM
adamg101
Nov 7, 2007 10:38 PM
Brians
Aerostar
Feb 7, 2007 03:04 PM
