The cleaning is the most tedious part, If you haven't already, you may consider putting a magnet in the bottom of the pan to catch any small pieces of metal.
Yes, so much cleaning. scraping off 30 year old gasket material from the valve body sandwich. So much time...
Also, magnets only catch the steel, not aluminum (what the case and valve body is made of).
Well got everything cleaned up and the trans put back together. Just gotta put the bell housing on and its ready to be installed!
Gonna get some new u joint also.
Also last time I put trans in my brother in law was here to help this time gonna be by myself so gotta rig up a tranny jack. Found some good DIY ideas hope it works out
I'm curious to know which shift kit you installed, and what you thought of it? I'm rebuilding my 4.9L 300 right now (basically stock rebuild), and I am entertaining the idea of pulling the trans for thorough inspection, cleaning, and possible rebuild. I've never used a shift kit, and I'm not sure if it's desired/beneficial for a stock truck. Thanks for the feedback!
I hope you get yours back on the road soon, and don't have issues for 300k miles, and not just 300 !!!
I installed a B&M shift kit. The install was easy and straight forward. I did the Street/strip
From B&M website
Shift Improver Kit - 1967 to 1969 Ford, Lincoln, Mercury C4 Application: 1967 to 1969 Ford, Lincoln, Mercury C4 Recalibrate your automatic transmission for optimum performance and extended life! Select the mode that best suits your application Provides crisp shifts on any stock automatic transmission Eliminates shift overlap and excess wear on clutches and bands due to slippage The B&M Shift Improver Kit the easiest way to get the stout performance you've always wanted out of your automatic transmission - and you get two modes of performance to select from: Heavy Duty, or Street/Strip. It's our least expensive and simplest to install kit. All you need are some hand tools! In the space of an afternoon, you can turn your transmission into a B&M-tuned unit! Ask the thousands of satisfied customers that have installed one in their transmissions! STAGE 1. HEAVY DUTY Firm positive shifts without loss of driver comfort for improved performance in all street vehicles. Recommended for regular passenger vehicles. STAGE 2. STREET/STRIP Provides positive shifts for high performance street use or for competitive events. This level is for the enthusiast who wants the hardest, quickest possible shift.
Well not sure what i messed up on this time. Has drive sometimes and slips really bad. Im done think im gonna pull trans and take it to a shop to have them go threw it.
O well!
Ok trans was rebuilt by the shop and picked up yesterday the clutches were detroyed I guess i used a wrong seal on one of them and it also ate up some other parts. So heading into the garage to install the transmission.
So to close this thread out well I hope. Got the transmission in yesterday and filled up with fluid. Drove the truck up the road and all seems fine. The trans shop wants me to bring the truck by there shop so they can make sure it’s working properly and then will give me a 12 month warranty.
