Modified or from Ford?
Old Apr 13, 2018 | 06:44 PM
Grand Illusion's Avatar
Grand Illusion
Trailering
The other day I was filling my F350 with diesel when I noticed a small amount dripping onto the ground under the truck. When I got home, I got on the creeper and took a look under the truck. On the filler tube, just as it begins to cross the frame on its way from the filler to the tank, there is what looks to be a small inlet with a piece of hose coming off of it that goes nowhere (and is open). The end of the hose is jagged so I doubt it's a factory cut. So, is this added on for some unknown reason or was something cut off? Any ideas? It's a 2017 Lariat diesel dually that I just picked up used.
Old Apr 13, 2018 | 07:00 PM
Snowman 8's Avatar
Snowman 8
That’s not from ford. Looks like some lazy a&& removed an auxiliary in box fuel tank that had some sort of gravity feed or fuel pump to fill the fuel tank. They just cut the fuel line with a knife and didn’t even bother to plug the hole. It’s hard to see but it looks like there is a hole in the bottom of the bed where the fuel line used to go. Did you buy it from a dealer or private party?
Old Apr 13, 2018 | 07:03 PM
Grand Illusion
Trailering
Good eye. Yes, I guess that would explain the 3/4" hole in the front corner of the bed.
Old Apr 13, 2018 | 07:06 PM
Snowman 8's Avatar
Snowman 8
I would get that hose plugged asap! It’s open for dirt water or whatever else to get in the tank. I you bought it from a dealer I would bring it right back and ask how they missed that in an inspection!
Old Apr 13, 2018 | 07:14 PM
Grand Illusion
Trailering
It was a trade taken in at an Audi dealer. I traded off a 16 F350 for the towing increase. The truck actually has three holes in the front lower corners of the box. Two on the filler side and one on the passenger. Any ideas what else I might want to look for? It's gonna have to go back to a ford dealer real soon for some warranty work (looks like the rear transfer case seal might be leaking. The entire underside of the truck and transfer case in that area is oil soaked). I don't like surprises, especially on something that cost nearly as much new as my first two houses put together!
Old Apr 13, 2018 | 07:21 PM
Xwild's Avatar
Xwild
1 of each of those holes may have been to bolt down the transfer tank.
Old Apr 13, 2018 | 08:32 PM
Snowman 8's Avatar
Snowman 8
What Xwild said, some of the holes would be for holding the tank down.
Old Apr 13, 2018 | 09:03 PM
xxxsherpa's Avatar
xxxsherpa
I don't own a diesel but that whole set-up looks non factory.
Old Apr 14, 2018 | 12:21 AM
Buliwyf's Avatar
Buliwyf
Yep, ghetto in bed fuel tank installed by a neck. Remove that garbage and go back to OEM.
Old Apr 14, 2018 | 12:33 PM
stewy604's Avatar
stewy604
Wow...now thats some shotty work!
Old Apr 15, 2018 | 08:58 AM
BronzefireAL13SD's Avatar
BronzefireAL13SD
Plug the hole. It's a non issue.
Kiknyoazz
Feb 10, 2019 03:05 AM
dziwei
Jun 11, 2018 08:36 PM
GeorgePBurdell
1983 - 2012 Ranger & B-Series
Jul 10, 2015 11:28 AM
abyars111
15
Oct 2, 2013 12:19 PM
JHoffman93
Mar 10, 2013 06:11 PM
